Podcast searching
How can I expand podcast searching?
For example I’m searching a Podcast ā€œMusica Maestroā€ di Armando Torno. It is easy to find with all the podcast app, but on Audirvana there isn’t. Also ā€œlezioni di Musicaā€ a Podcast of Rai Radio3.
@Antoine
Hi @Angelos58,
Can you confirm you are talking about these?
Yes, Musica Maestro.
Lezioni di Musica not only 2016
Then?
@Antoine
I will need to see if we can access those podcasts. I will let you know as soon as possible.
Hi @Angelos58,
It seems they are not in the airable catalog. I will ask them to add the podcasts for rai radio 3.
Hi @Angelos58,
Airable came back to me about those podcasts:
  • there are no active podcasts from Rai Radio 3 (or Rai in general) in their database. Looking at the Rai podcasts it seems like they’re only available on their website and on ā€œRaiPlay Soundā€. They couldn’t find find any public feed URLs which they need to add them into their database.
  • They found the ā€œMusic Masetroā€ podcast and they added it to the Airable Database.
