I use Audirvana on a Mac mini 2012 controlled from the A / iPad remote.
Listening to a Flac MQA 24/96 from TIDAL, the color that appears in the Poly / Mojo corresponds to 48Kbps and not 96 Kbps.
How to set Audirvana to the right color (green according to Poly / Mojo)?
Hello @Vnunes, Can you send me a copy of the “Debug Info” while you are connected to your DAC? You can get it in Audirvana Settings>General>Debug Info
Hello Damien3
Thank you for your quick response, but I, too, continued to investigate.
I have two Macs both with Audirvana installed, one just for music (MacMini with OS 10.13.6) and another for normal work (MacBook Air with OS 10.15.3). The last one Audirvana works as expected with Poly / Mojo.
The first one does not work as expected. I suppose the only difference between them has to do with the OS version.
Below I send the MacMini “debug info” and, if needed I can send to you the “debug info” for the MacBook Air ".
Hoping to hear from you,
Vitor Nunes
Audirvana Mac Version 3.5.30 (3560)
macOS 10.13.6 with 16384MB RAM
Registered to Vitor Nunes
Sync list: 0 folders
Library database path: /Users/mac/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: Chord Poly:Poly [Renderer] Model UID:JF Light Industries Chord Poly:Poly [Renderer] UID:uuid:ec1f9952-cef5-7bf7-9240-dcefca914358
Currently playing to UPnP device at 24 bits 48kHz
UPnP device at http://192.168.1.76:49152/description.xml
ID 0x0 Chord Poly:Poly [Renderer] Manufacturer:JF Light Industries
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::application/flac:*
http-get::application/x-flac:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Can play native DSD: Yes
14 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:07:40
CurrentURI: http://192.168.1.77:49155/audirvana/audio_0_0.wav
CurrentURIMetadata: <?xml version="1.0" encoding="utf-8"?>dc:titleParsifal, WWV 111, Act 3: Prelude</dc:title>mpdupnp:classobject.item.audioItem.musicTrack</upnp:class>upnp:albumBruckner: Symphony No. 9 - Wagner: Parsifal (Excerpts)</upnp:album>upnp:originalTrackNumber1</upnp:originalTrackNumber>http://192.168.1.77:49155/audirvana/audio_0_0.wavdc:creatorConcertgebouworkest</dc:creator>upnp:artistConcertgebouworkest</upnp:artist>
nextURI: http://192.168.1.77:49155/audirvana/audio_1_1.wav
nextURIMetadata:
dc:titleParsifal, WWV 111, Act 3: Karfreitagszauber</dc:title>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://resources.tidal.com/images/74a87765/d099/4d56/93c3/2c35480678f8/640x640.jpg</upnp:albumArtURI>
PlayMedium: HDD
<?xml version="1.0"?> 1 0 TransportState no string STOPPED PLAYING TransportStatus no string OK ERROR_OCCURRED PlaybackStorageMedium no string PossiblePlaybackStorageMedia no string RecordStorageMedium no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL RANDOM DIRECT_1 NORMAL TransportPlaySpeed no string 1 no RecordMediumWriteStatus string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 2000 1 CurrentTrack no ui4 0 2000 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no i4 CurrentTransportActions no string LastChange yes string A_ARG_TYPE_SeekMode no string ABS_TIME REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Chord Poly:Poly [Renderer] JF Light Industries [https://opensourceprojects.eu/u/medoc/profile/](https://opensourceprojects.eu/u/medoc/profile/%3C/manufacturerURL%3E) UPnP front-end to MPD UpMPD 1.0 [https://opensourceprojects.eu/p/upmpdcli/code/](https://opensourceprojects.eu/p/upmpdcli/code/%3C/modelURL%3E) 42 uuid:ec1f9952-cef5-7bf7-9240-dcefca914358 image/png 64 64 32 /upmpd/icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upmpd/RenderingControl.xml /ctl/RenderingControl /evt/RenderingControl urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upmpd/AVTransport.xml /ctl/AVTransport /evt/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upmpd/ConnectionManager.xml /ctl/ConnectionManager /evt/ConnectionManager /upmpd/presentation.html [http://192.168.1.76:49152/](http://192.168.1.76:49152/%3C/URLBase%3E)UPnP devices found : 1
Device #0: ID 0x0 Chord Poly:Poly [Renderer] UID: uuid:ec1f9952-cef5-7bf7-9240-dcefca914358 Location: http://192.168.1.76:49152/description.xml
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:33 UID: AppleHDAEngineOutput:1B,0,1,2:0
You need to set it to “Not MQA”.
Done.
Ok now.
Thank you
Vitor
