Popping noise
Seems to be at beginning of track or end. Might have started after most recent update. Any ideas audirvana is new to me.
Can you paste the debug info here?
Hello @Myopposablethum,
udirvana Origin 2.1.0 (20100)
macOS 12.6.1 with 16GB physical RAM
Connected account of : Peggy Heil
Sync list: 2 folders
AUTO: /Users/peggyaheil/Downloads
AUTO: /Volumes/First music/
Library database path: /Users/peggyaheil/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 64086
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
Built-in Output
Model UID:
UID:
Active Sample Rate: 192kHz
Sample rate switching latency: 0.5s
Limit bitdepth to 24bit: ON
Selected device:Schiit Gungnir Unison USB
Manufacturer: Schiit Audio
Model name: Schiit Audio Schiit Gungnir Unison USB
Model UID: Schiit Gungnir Unison USB:30BE:1002
UID: AppleUSBAudioEngine:Schiit Audio:Schiit Gungnir Unison USB:14600000:1
USB Vendor ID: 0x30be
USB Product ID: 0x1002
ID 0x32
Stream ID 0x33 2 channels starting at 1
24 virtual formats:
36 physical formats
Device #0: ID 0x2b Built-in Output
Model UID: AppleHDA:108
Device #1: ID 0x32 Schiit Gungnir Unison USB
UPnP devices found : 9
Device #0: ID 0x0 : DP-UB820
UID: uuid:4D454930-0100-1000-8000-B46C47690473
Location: http://192.168.0.144:60606/B46C47690473/Server0/ddd
Manufacturer: Panasonic
Model name: Blu-ray Disc Player
Device #1: ID 0x0 : Marantz AV7703
UID: uuid:b2f749dc-ea2e-1425-0080-0005cde93a16
Location: http://192.168.0.55:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Marantz
Model name: Marantz AV7703
Device #2: ID 0x0 : Marantz AV7703
UID: uuid:5012d69b-b13f-19a8-0080-0005cde93a16
Device #3: ID 0x0 : Marantz AV7703
UID: uuid:1fadb87b-3fca-e7c3-824c-7c095242c954
Device #4: ID 0x0 : Marantz AV7703
UID: uuid:8d82e42f-f449-1898-0080-0005cde93a16
Device #5: ID 0x0 : Marantz AV7703
UID: uuid:25e3ed98-5e11-26c5-48fc-8b2ace673142
Device #6: ID 0x0 : [TV] Samsung Q6 Series (65)
UID: uuid:ffc40510-3173-4ed0-8c57-b81892e6907f
Manufacturer: Samsung Electronics
Model name: QN65Q6FNA
Device #7: ID 0x0 : DESKTOP-RVT8CNS
UID: uuid:9be37d80-3d94-438d-8f34-3c342e31e672
Location: http://192.168.0.84:52101/DeviceDescription.xml
Manufacturer: JRiver, Inc.
Model name: Media Center
Device #8: ID 0x0 : [LG] webOS TV OLED65C9PUA
UID: uuid:c4550dfb-5f03-7585-da35-7299914937ef
Manufacturer: LG Electronics.
Model name: LG TV
Can you remove the settings you set here and try again to reproduce your issue?
I have also this popping noise e.g. when one track merges into the following without a short break.
With Audirvana 3.5.50 there is no popping noise. I have this on a MacBook and a Mac mini.
