Popping sounds during fast transients while using DSD to PCM conversion
Running Audirvana 3.5.42 on Windows 10 (Build 19041). When playing DSD/DSF files with a Schiit Bifrost 2 via USB and the DSD audio output set to “none: convert to PCM” I get noticeable popping/crackling sounds when fast transient sounds (like kick drum hits) happen. Music still plays but this popping/crackling is persistent. It doesn’t always start right away when a track plays, but after 2 or 3 minutes of playtime it will start. This issue does not happen with PCM files of any bit depth or sampling rate. I switched to my older SMSL SU-8 (also via USB) to check and the popping/crackling still happens with it when Audirvana converts DSD/DSF to PCM, but the popping does not happen if Audirvana is set to output the DSD in native format. Any ideas?
Hello @WaveTheory,
If your DAC is compatible with DSD over PCM, you can set the native DSD read method to “DSD over PCM 1.0” in the device section of the audio settings page.
If your DAC has a volume control, you may need to ensure it is set at 100% during DSD playback to prevent its USB interface from damaging the DSD signal.
The Bifrost 2 has neither dsd decoding nor volume control. I tried both “DSD over PCM 1.0” and 1.1 and get nothing but low level white noise with each. As stated above, the SMSL SU-8 which does have dsd decoding has the same issue when Audirvana converts dsd to pcm but plays the native dsd fine. I would like to use the Bifrost 2 though as it is the clearly superior dac.
Can you send me a copy of the “Debug Info” while you have selected your Bifrost 2? You can get it in Audirvana Settings>General>Debug Info
Here ya go. I did this while playing the Dark Side of the Moon DSD64 album:
Audirvana 3.5.42
AUTO: D:\Music
Library database path: C:\Users\bdfar\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4132MB
Local Audio Engine:WASAPI
Speakers (2- Schiit Bifrost 2 Unison USB )
Model UID:Speakers (2- Schiit Bifrost 2 Unison USB )
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{7c0e1bcf-8f8c-4775-9104-27737841b604}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 32bits Integer, 8 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Speakers (2- Schiit Bifrost 2 Unison USB ) Manufacturer:
Model UID:Speakers (2- Schiit Bifrost 2 Unison USB ) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{7c0e1bcf-8f8c-4775-9104-27737841b604}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Local devices found : 7
Device #0: Speakers (Steam Streaming Microphone) Manufacturer: Model UID: Speakers (Steam Streaming Microphone) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{5b2d37f8-941b-4a86-8076-9cf24430b514}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (Steam Streaming Speakers) Manufacturer: Model UID: Speakers (Steam Streaming Speakers) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{2f24dd0d-3835-402a-bb85-c2dade2bb5b2}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Realtek Digital Output (Realtek High Definition Audio) Manufacturer: Model UID: Realtek Digital Output (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{d2c2a9fa-3854-4789-b36f-0b4991661ab2}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: Speakers (2- Schiit Bifrost 2 Unison USB ) Manufacturer: Model UID: Speakers (2- Schiit Bifrost 2 Unison USB ) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{7c0e1bcf-8f8c-4775-9104-27737841b604}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #4: Speakers (ATR USB microphone) Manufacturer: Model UID: Speakers (ATR USB microphone) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{fe48299e-c770-4e09-a98c-c50d824ed113}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #5: Speakers (2- Schiit Unison Modius ) Manufacturer: Model UID: Speakers (2- Schiit Unison Modius ) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{1295872e-e7e8-4702-a9b7-833f68ab5836}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #6: Realtek Digital Output(Optical) (Realtek High Definition Audio) Manufacturer: Model UID: Realtek Digital Output(Optical) (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{a148f38f-2388-4b40-9424-d2060ccf1588}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Have you tried fixed resampling to 192KHz?
Interesting idea. I tried it and it didn’t help.
I’m a new user and had the same problem so I dug into the audio settings and saw that next to “convert DSD to PCM”, “+6DB” was selected. I couldn’t change it to zero, however, until I disconnected my DAC and “MacBook Speakers” was the device name. I changed it to zero, plugged my DAC back in and It fixed the problem. Apparently +6bd is the default setting for DSD to PCM conversion.
Thanks for the suggestion. So far it’s made it through several DSD tracks without issue. I’m not ready to say ‘solved’ yet but I’m encouraged :slightly_smiling_face:
I have exactly the same problem, but on hdmi (wasabi) out
+0 or +1 solved the problem partly but not completely
Some tracks with extra wide range still have problem
Dac usb output without pcm conversion - hasn’t problem
