Hi! I’m using the Audiolense Convolver (ALC) for crossovers, room correction etc. The DAC is a RME UFX. I’m playing from Qobuz with Audirvana 3.5.46, and if I play a track with different samplerate than the current one I get pops. The DAC seems to reset and sets the correct samplerate. Also the ALC user interface shows the correct samplerate. If I stop the track, deselect “Use extra convolver buffer” in the ALC user interface, press play, then stop again and finally select “Use extra convolver buffer”, the pops are gone until I play a track with different samplerate again. When I start Audirvana I don’t get any pops before changing to a track with different samplerate. Maybe a timing problem with resetting DAC, Audiolense or Audirvana? I installed Roon yesterday, and there are no pops. Everything else is the same.
Hello @Cyberkul,
Can you send us a copy of the “Debug Info” when you have this issue? You can get it in Audirvana Settings>General>Debug Info
Please remove the line corresponding to your logged-in account to avoid displaying your email address and first name/last name publicly.
I started up Audirvana, played 1. No noise, then pressed Stop, played 2. Got noise, then pressed Stop, and finally played 3. Got noise.
- The Torture never stops 192kHz, startup of Audirvana, no noise
- Rollo 96kHz, noise
- The Torture never stops 192kHz, noise
Audirvana 3.5.46
Sync list: 0 folders
Library database path: C:\Users\xxxx\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4096MB
Local Audio Engine:ASIO 2 driver version 1
Audiolense
Model UID:Audiolense
UID:Audiolense
Active Sample Rate: 192kHz
Sample rate switching latency: 1s
Audiolense Manufacturer:
Model UID:Audiolense UID:Audiolense
Device #0: ASIO Fireface USB Manufacturer: Model UID: ASIO Fireface USB UID: ASIO Fireface USB
Device #1: Audiolense Manufacturer: Model UID: Audiolense UID: Audiolense
UPnP devices found : 1
Device #0[TV]UE55D8000 UID: uuid:9377c1df-65f6-8991-838c-944ebb26f34b Location: http://xxxxxx:xxx/dmr/SamsungMRDesc.xml
Can you try to enable upsampling and use the setting “device maximum frequency”?
Do you still get the issue after doing this?
The noise is gone if using upsampling to device max (192kHz), but the sound quality suffers. I can also use VB Hfi Cable/ ASIO bridge, and select WASAPI in Audirvana. Then select Audiolense in ASIO bridge. This works without noise. When I say without noise I don’t mean the short pop during samplerate change, but pops and cracles during playback. Will the WASAPI / ASIO bridge combo still be bit perfect?
If you select ASIO in Audirvana with he same configuration, do you have the pop and crackles issue?
VB Hifi cable is not available under the Audirvana Asio menu. Only Audiolense and RME UFX are available.
Hello,
I have more or less the same configuration, this means:
Qobuz>Audirvana(3.5or studio)>AcourateConvolver>MAD(Merging driver)>Merging Anubis. I always have some issues with samplerate change!
If I dont use Acourate Convolver, no problem with change but then no correction or XO. If I play convolver>MAD no problem with samplerate change but then no Audirvana, then no music.
Nevertheless I can get around these issues but have to do it manually, this means stop the music before next song starts with another SR. Go to Acourate Convolver, choose the new SR, return to Audirvana, play…
My point is that I need a player program with the possibility to include the convolver function. This way I will have only one Asio connection: Qobuz>Xplayer>MAD.
Thats why I will soon go with Roon, because of Qobuz, which is not possible with Jriver.
Hello @jorgen,
Audirvana 3.5.46
Bandwidth at 0dB = 97.4371
Filter max length = 22380
Anti-aliasing = 96.9664
Manual: (OFFLINE) D:\Musik
Library database path: C:\Users\skadh\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 618MB
Local Audio Engine:ASIO 2 driver version 0
AcourateASIO
Model UID:AcourateASIO
UID:AcourateASIO
AcourateASIO Manufacturer:
Model UID:AcourateASIO UID:AcourateASIO
0 available sample rates up to 0Hz
Simple stereo device: No
0 output streams:
Number of active channels: 2
Local devices found : 3
Device #0: AcourateASIO Manufacturer: Model UID: AcourateASIO UID: AcourateASIO
Device #1: Merging Audio Device Manufacturer: Model UID: Merging Audio Device UID: Merging Audio Device
Device #2: Realtek ASIO Manufacturer: Model UID: Realtek ASIO UID: Realtek ASIO
Hello here debug from Plus and her from Studio:
Version actuelle: 1.3.0 (10030)
No plugin active
Bandwidth = 95.0011%
Library database path: C:\Users\skadh\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 172.16.0.3 on port 51924
Max. memory for audio buffers: 710MB
Local Audio Engine: ASIO ASIO 2 driver version 1
Model UID:Merging Audio Device
Active Sample Rate: 352.8kHz
Manufacturer:
Model Name: Merging Audio Device
11 available sample rates up to 11289600Hz
5644800
11289600
DSD capability: Raw DSD (MSB)
Multichannel: 8 channels
Channel bitmap: Ox63f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Number of channels: 8
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
8 ch Integer PCM 24bit little endian 44.1kHz
8 ch Integer PCM 24bit little endian 48kHz
8 ch Integer PCM 24bit little endian 88.2kHz
8 ch Integer PCM 24bit little endian 96kHz
8 ch Integer PCM 24bit little endian 176.4kHz
8 ch Integer PCM 24bit little endian 192kHz
8 ch Integer PCM 24bit little endian 352.8kHz
8 ch Integer PCM 24bit little endian 384kHz
8 ch DSD 8bit big endian in 8bit chunk 2822.4kHz
8 ch DSD 8bit big endian in 8bit chunk 5644.8kHz
8 ch DSD 8bit big endian in 8bit chunk 11289.6kHz
Device #0: AcourateASIO Manufacturer: Model UID: AcourateASIO UID: AcourateASIO Model Name: AcourateASIO
Device #1: Merging Audio Device Manufacturer: Model UID: Merging Audio Device UID: Merging Audio Device Model Name: Merging Audio Device
Device #2: Realtek ASIO Manufacturer: Model UID: Realtek ASIO UID: Realtek ASIO Model Name: Realtek ASIO
If you go in the ASIO driver of Acourate, do you have any sample rate detected?
yes I see the actual samplerate being played
Hi! Seems to be the same as my issue. When SR changes, the correct SR is shown both in the Audiolense convolver, and on the RME display. Have not found any other solution than to move to Roon. Have now used Roon for a few weeks, and the problem is gone. Setup is the same, using Audiolense convolver as the (virtual) ASIO sound card.
Do you have the same issue with the latest version of Studio?
Don’t know, It was installed a fee weeks ago. The trial period is now over.
