Recently, the preload audio file speed of my studio has become very slow. Not only the streaming music will be played intermittently, but also the local audio file. Excuse me, whatās the problem?
Audirvana Studio 2.9.5 (20906)
macOS 12.7.6 x86_64 with 8GB physical RAM
Connected account of : spark wu
Per track: OFF
r8brain with Power Of Two upsampling
SW volume control: ON
Sync list: 2 folders
AUTO: /Users/spark/Music/é³ęØ
AUTO: /Volumes/SPARK256/
iTunes/Music library synchronization: last synchronized on Sun Oct 20 11:53:55 2024
Sort and display order: zh_Hant_TW
Library database path: /Users/spark/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 14701
Listening on 127.0.0.1 on port 49216
TIDAL: Connected as PREMIUM
Font size: regular
Language: English
My Music
Radios
Podcasts
Streaming
Use Apple Remote: yes
Number of paired remotes: 3
Screen saver disabled: yes
Max. memory for audio buffers: 2352MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: OFF
Actual I/O buffer frame size: 4096
DENAFRIPS DENAFRIPS USB Audio V3.12 | A22FA1.6
Model UID:DENAFRIPS USB Audio V3.12 | A22FA1.6:152A:86EF
UID:AppleUSBAudioEngine:DENAFRIPS:DENAFRIPS USB Audio V3.12 | A22FA1.6:14200000:1
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 1411.2kHz
Active Sample Rate: 1411.2kHz
Hog Mode is on
Selected device:DENAFRIPS USB Audio V3.12 | A22FA1.6
Manufacturer: DENAFRIPS
Model name: DENAFRIPS USB Audio V3.12 | A22FA1.6
Model UID: DENAFRIPS USB Audio V3.12 | A22FA1.6:152A:86EF
UID: AppleUSBAudioEngine:DENAFRIPS:DENAFRIPS USB Audio V3.12 | A22FA1.6:14200000:1
USB Vendor ID: 0x152a
USB Product ID: 0x86ef
ID 0x4d
12 available sample rates up to 1536000Hz
1411200
1536000
DSD via PCM 1.0
Stream ID 0x4e 2 channels starting at 1
24 virtual formats:
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1536kHz
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1411.2kHz
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 1536kHz
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 1411.2kHz
24 physical formats
2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 1536kHz
2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 1411.2kHz
Device #0: ID 0x38 Built-in Output
Model UID: AppleHDA:123
Device #1: ID 0x4d DENAFRIPS USB Audio V3.12 | A22FA1.6
Wi-Fi
