Using v3.5.14 on a MacBook Pro under OS Mojave. Want to change audio output. Message “Please stop playback to change audio settings” I have one CD in my library and it is not playing. I have Bongiovi Acoustics installed but not loaded when Audirvana is running. Nothing I do removes the message, therefore I cannot change output.
Audirvana Mac Version 3.5.14 (3544)
macOS 10.14.5 with 16384MB RAM
Registered to Duncan Jones
AUTO: /Volumes/6 Tb - Music I 1/L - P/O/Orchestral Manoeuvres in the Dark/2016 - Architecture and Morality, Dazzle Ships - Live at the Royal Albert Hall
Library database path: /Users/duncanjones/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
CoreAudio audio path, buffer I/O frame size: 4096
BH900
Model UID:ffff 0
UID:00-17-53-06-0f-91:output
Hog Mode is on
ID 0x2a DPSReflector Manufacturer:Bongiovi Acoustics
Model UID:DPSAudioReflector UID:DPSReflectorEngine:0
1 available sample rates up to 44100Hz
Stream ID 0x2b 2 channels starting at 1
1 virtual formats:
2 physical formats
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 44.1kHz
2 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 44.1kHz
Local devices found : 6
Device #0: ID 0x58 DisplayPort Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:0:{FF7F-9000-0000000E}
Device #1: ID 0x4e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:57 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #2: ID 0x2a DPSReflector Manufacturer: Bongiovi Acoustics Model UID: DPSAudioReflector UID: DPSReflectorEngine:0
Device #3: ID 0x45 MMAudio Device Manufacturer: MMAudio Device contributors Model UID: MMAudioDeviceModelUID UID: MMAudioDevice
Device #4: ID 0x4a MMAudio Device (UI Sounds) Manufacturer: MMAudio Device contributors Model UID: MMAudioDeviceModelUID_UISounds UID: MMAudioDevice_UISounds
Device #5: ID 0x33 AirParrot Manufacturer: squirrels Model UID: com_squirrels_driver_AudioDevice:AirParrotSpeakers UID: com_squirrels_driver_AudioEngine:0
