Hi. I can’t read 24 bit / 44.1 kHz WAV files through my Lexicon Alpha USB DAC. 16 bit or other formats are fine. I have an recent Mac Mini, when I try to read my 24 bit files using directly the Mac output it works for Audirvana. What’s the problem ? Do I have the wrong setup for the DAC in Audirvana or is the problem with my DAC ?
Audirvana Mac Version 3.5.37 (3567)
macOS 10.15.4 with 8192MB RAM
Licence enregistrée pour
AUTO: /Volumes/MAXTOR/***DD MAC MINI/MUSIC
Library database path: /Volumes/MAXTOR/***DD MAC MINI/MUSIC/AudirvanaPlusDatabaseV2.sqlite
Lexicon Alpha In/Out
Model UID:Lexicon Alpha In/Out:1210:000A
UID:AppleUSBAudioEngine:Lexicon:Lexicon Alpha:14600000:2,1
Active Sample Rate: 48kHz
ID 0x4e Lexicon Alpha In/Out Manufacturer:Lexicon
Model UID:Lexicon Alpha In/Out:1210:000A UID:AppleUSBAudioEngine:Lexicon:Lexicon Alpha:14600000:2,1
2 available sample rates up to 48000Hz
Stream ID 0x4f 2 channels starting at 1
6 virtual formats:
8 physical formats
Local devices found : 3
Device #0: ID 0x4e Lexicon Alpha In/Out Manufacturer: Lexicon Model UID: Lexicon Alpha In/Out:1210:000A UID: AppleUSBAudioEngine:Lexicon:Lexicon Alpha:14600000:2,1
Device #1: ID 0x51 Écouteurs externes Manufacturer: Apple Inc. Model UID: Codec Output UID: BuiltInHeadphoneOutputDevice
Device #2: ID 0x48 Haut-parleurs Mac mini Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Hello Damien,
Thank you for your fast answer. VLC / Mac Mini is ok. It’s also ok with my streamer Atoll DAC (ethernet). Maybe I need to setup Audirvana for the Lexicon DAC or take a new (and better) DAC, or a headphone amplifier ? I mostly listen to music via my headphone or the Atoll DAC (I know that I need better material to listen with my headphone directly through the Mac, but I don’t know what to buy).
Preferred device: ATOLL Streamer Model UID:ATOLL Electronique ATOLL Streamer UID:uuid:d64f65b9-3980-4488-973c-3fc9097d6c24
UPnP device at http://192.168.1.18:38780/d64f65b9-3980-4488-973c-3fc9097d6c24.xml
ID 0x0 ATOLL Streamer Manufacturer:ATOLL Electronique
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/vorbis:
http-get::audio/flac:
http-get::audio/x-aiff:
http-get::text/xml:
http-get::audio/ogg:
http-get::application/ogg:
http-get::audio/m4a:
http-get::audio/wav:
http-get::audio/x-m4a:
http-get::audio/x-wav:
http-get::audio/aac:
http-get::audio/x-dsf:
http-get::audio/x-flac:
http-get::audio/mpeg:
http-get::audio/x-dff:
http-get::audio/aiff:
http-get::audio/wave:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/x-dff:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/wave:
DLNA 1.5: Yes
Gapless playback: Yes
Can play native DSD: Yes
14 virtual formats:
0 physical formats
NrTracks: 2
MediaDuration: 0:00:00
CurrentURI: http://192.168.1.14:49152/audirvana/audio_1_15.wav
CurrentURIMetadata:
dc:titleSex Kino - She_s Gotta Move [K-Effect Master]</dc:title>
upnp:albumSex Kino - SCREAM IN THE CITY (EP)</upnp:album>
nextURI: http://192.168.1.14:49152/audirvana/audio_0_16.wav
Sex Kino - Something Inside of You (k effect master)
Sex Kino
Sex Kino
object.item.audioItem.musicTrack
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED CurrentMediaCategory string NO_MEDIA TRACK_AWARE TRACK_UNAWARE CurrentTransportActions string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD PossiblePlaybackStorageMedia string NONE NETWORK PossibleRecordStorageMedia string CurrentPlayMode string NORMAL REPEAT_TRACK REPEAT_ONE REPEAT_ALL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 512 CurrentTrack ui4 0 512 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 LastChange string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME TRACK_NR ABS_COUNT REL_COUNT X_DLNA_REL_BYTE A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 ATOLL Streamer ATOLL Electronique https://www.atoll-electronique.com/ ATOLL Streamer http://www.atoll-electronique.com/ 1940000068 uuid:d64f65b9-3980-4488-973c-3fc9097d6c24 image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.1.18:80/ DMR-1.50UPnP devices found : 1
Device #0: ID 0x0 ATOLL Streamer UID: uuid:d64f65b9-3980-4488-973c-3fc9097d6c24 Location: http://192.168.1.18:38780/d64f65b9-3980-4488-973c-3fc9097d6c24.xml
Can you try to enable upsampling in your audio output settings in Audirvana? After doing so can you try to play the same song?
Hi. I tried to enable upsampling but it doesn’t work (with all different options). Is it normal ? What about my previous questions ? “take a new (and better) DAC for the Mac, or a headphone amplifier ? I mostly listen to music via my headphone or the Atoll DAC (I know that I need better material to listen with my headphone directly through the Mac, but I don’t know what to buy).”. I think it’s time to change my Lexicon DAC If you have any advices it would be much appreciable.
With some DACs there are issues. It’s not a good reason on itself to change the DAC. Keep using it without upsampling if you like the sound.
