Not sure if that’s associated with the SSL bug on the website or not, but currently attempting to update A+3.0.2 to 3.0.3 results in the application prompting me to update. When accepting, the progress meter runs, but on Install and Relaunch, the app quits but does not return. Restarting A+ returns me to 3.0.2.
Same problem for me. I ended up going to the website, downloading 3.0.3 and installing it manually.
Même problème pour moi. Même solution que aero12
I updated my other computer today and it worked fine. I suspect it had to do with the bad SSL cert on the website yesterday.
Seems resolved.
