Hello,
Since update 3.5.42, the remote control (Samsung A51) does not work anymore.
I checked my network, the firewall and restart my wifi…
Without success…
What can I do …
Before the update the remote control was working perfectly…
In advance, thank you…
John T
carloll
November 12, 2020, 8:42am
2
Tartopom68:
3.5.42
Hi,
i have the same problem as you after updating to 3.5.42, from that moment the remote on android does not connect.
I turned on a second PC in a different audio system which worked remotely for about 30 minutes with the old version 3.5.41, after switching to the new version the remote control interrupted the connection.
I reported to Audirvana support, who kindly gave me support, but to date the remote is unusable.
Carlo
Antoine
November 12, 2020, 8:44am
3
Hello @carloll and @Tartopom68 ,
Can you go in Audirvana settings>Miscellaneous, can you enable the settings to use the older verison of the connexion process for the Remote?
carloll
November 12, 2020, 10:09am
4
Hi Damien, I searched everywhere in miscellaneous menù, but i can’t find the voice for remote control, in total I see just four options.
Win10 Pro, Audirvana 3.5.42
Antoine
November 12, 2020, 10:13am
5
It’s the last one: “Use legacy Bonjour library fro detection by Remote”
carloll
November 12, 2020, 10:38am
6
I haven’t written before, but I’ve already tried
Hello,
it still doesn’t work…
Too bad…
Before the update everything was perfect… since the update it’s a pain in the ass.
Another solution…?
Antoine
November 12, 2020, 11:18am
8
enabling the button didn’t work to conect the Remote?
Unfortunately…no
whatever the position of the button, the remote control does not work
Antoine
November 12, 2020, 11:23am
10
Have you tried to reinstall the Remote on your device?
Hello,
It’s OK, you have to set the button to ON, close AUdirvana on the PC and restart it.
Then start the app on the phone.
It works…
KinG
November 14, 2020, 1:14pm
12
@Antoine what should I do if the mentioned above doesn’t help in my case? I can’t connect to my PC neither from Android nor from iPad.
KinG
November 14, 2020, 1:21pm
13
I get pairing code, enter it and nothing happens.
carloll
November 16, 2020, 9:00am
14
in my case I solved it after I deactivated **“Rescan folders for changes at each start”
KinG
November 16, 2020, 9:21am
15
Unbelievable! The issue is also solved on my side right after I deactivated the option. Thanks!
THXKO
November 16, 2020, 8:33pm
17
I’m just going to play the first track and then the app crashes.
system
Closed
November 26, 2021, 8:33pm
18
