I’m on the latest version of Audirvana and Mac OSX. When the app loads Audio Unit it does not render the screen correctly. It renders the AU window as a square aspect rather than the full width of the AU control window. Screen shot attached. Also when I am in dual monitor mode then half of the AU window is rendered off the left hand side of the screen on my larger monitor.
Many thanks,
Jonathan
Audirvana Mac Version 3.5.30 (3560)
macOS 10.15.3 with 65536MB RAM
Registered to Jonathan Murray
AU plugin #0: Music Effect - FabFilter FF Pro-Q 3 ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
AUTO: /Users/Jonathan/Music/High Resolution Audio
Library database path: /Users/Jonathan/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
CoreAudio audio path, buffer I/O frame size: 4096
Max. memory for audio buffers: 62464MB
Exclusive access: Disabled
32bit 384kHz Dsd Interface
Model UID:32bit 384kHz Dsd Interface:27F7:1301
UID:AppleUSBAudioEngine:Wyred 4 Sound:32bit 384kHz Dsd Interface:413-001:2
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 384kHz
Active Sample Rate: 384kHz
ID 0x39 32bit 384kHz Dsd Interface Manufacturer:Wyred 4 Sound
Model UID:32bit 384kHz Dsd Interface:27F7:1301 UID:AppleUSBAudioEngine:Wyred 4 Sound:32bit 384kHz Dsd Interface:413-001:2
32000
Audio buffer frame size : 106 to 4096 frames
Stream ID 0x3a 2 channels starting at 1
18 virtual formats:
18 physical formats
Local devices found : 4
Device #0: ID 0x6e LG HDR 4K Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:30001:0:{6D1E-7707-000447F5}
Device #1: ID 0x2e USB AUDIO CODEC Manufacturer: BurrBrown from Texas Instruments Model UID: USB AUDIO CODEC:08BB:29C3 UID: AppleUSBAudioEngine:BurrBrown from Texas Instruments:USB AUDIO CODEC:14224432:1
Device #2: ID 0x39 32bit 384kHz Dsd Interface Manufacturer: Wyred 4 Sound Model UID: 32bit 384kHz Dsd Interface:27F7:1301 UID: AppleUSBAudioEngine:Wyred 4 Sound:32bit 384kHz Dsd Interface:413-001:2
Device #3: ID 0x62 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
