Hi
It appears that all DLNA endpoints are given the same settings. This is a problem if you want to switch between two or more which have different capabilities. As an example, the one I use in my study is attached to a DAC which supports rates up to 384 kbps, while the one in the main system only supports rates up to 96 kbps, If Iāve been using the study system I have to remember to change the rate in the settings otherwise my DAC cannot handle the signal.
Surely there should be separate settings for each?
Best regards
Alan
