Hello. I use audirvana on windows 10 for usb to DAC and I have a problem. after a few songs played, it stops as if the playlist has ended, although I know it definitely doesn’t stop after the last song. someone had a similar problem and solved it? Thx
Are you upsampling? Try without upsampling if you do.
No, i don’t use upsampling becase with upsampling i hear shoot in speaker.
Hello @majcher87,
Audirvana 3.5.42
AUTO: E:\Muzyka
Library database path: C:\Users\majch\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2090MB
Local Audio Engine:ASIO 2 driver version 536
Model UID:
UID:
TUSBAudio ASIO Driver Manufacturer:
Model UID:TUSBAudio ASIO Driver UID:TUSBAudio ASIO Driver
11 available sample rates up to 11289600Hz
5644800
11289600
DSD capability: Raw DSD (MSB)
Device #0: TUSBAudio ASIO Driver Manufacturer: Model UID: TUSBAudio ASIO Driver UID: TUSBAudio ASIO Driver
Device #1: XMOS USB Audio 2.0 ST 3033 Manufacturer: Model UID: XMOS USB Audio 2.0 ST 3033 UID: XMOS USB Audio 2.0 ST 3033
UPnP devices found : 1
Device #0[TV] tv majcher UID: uuid:baa3c1e0-6abd-48fc-ad78-f6995e34975a Location: http://192.168.8.165:9197/dmr
today i play four tracks and audirvana stop play
How much memory(RAM) you have in your computer?
Damien3 i got 8gb ram in nuc i7
Can you go in the audio output settings and change the maximum memory for audio buffer to 4000MB? If you still have the issue, can you try using WASAPI instead of ASIO?
yes i can change buffor and i try it later. In wasapi i dont have option native dsd only dop
It’s true but you were playing a 44,1 Khz track when you had the issue, right?
yes it’s true, for try i can change it, but i prefered asio because i play dsd too.
Damien3, nadal jest to samo, mimo zmiany bufora i asio/wasapi. Proszę o pomoc by audirvana działała bez przerw.
When you change from a track to another, does they have the same sample rate and bit depth?
it happens during one album (stops by itself) so all parameters should theoretically be the same
