Hi,
first of all I’m using KORG DS-DAC 100 USB device. When I use WASAPI driver then a problem occures. When the DAC is playing for example 44khz song and the next one is, for example, 96khz rated, then there is no problem with switching to the higher bitrate. But when the next song is 44khz, then the DAC doesn’t swich to 44khz and playback stops.
This problem however is not related to ASIO driver. Here everything is fine with going up and down with frequency playback.
I’m not converting or upsampling anything, just playing files as they are recorded.
Does anyone encountered similar problem? Any help would be neede here.
Best regards to all!
