Je n arrive plus à lire les tittres de qobuz sur mon DENON DRA-800H.
Sur Audirvana le titre se charge puis aucun son sur l ampli DENON .
Sur l ampli DENON à la suite du titre j ai le message impossible de lire le media.
Sur windows la diffusion multimedia est bien activé
En local sur Audirvana je lis bien mes fichiers de ma bibliotheque.
Audirvana Studio 3.5.51 (2051)
Windows 11 (22000) with 16GB physical RAM
Manual: (OFFLINE) \NASBernard\Partage\Musique
Library database path: C:\Users\berna\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Preferred device: Living Room Model UID:Denon Living Room UID:uuid:2b02164b-a6bc-145f-0080-0005cdbb4102
UPnP device at http://192.168.1.197:60006/upnp/desc/aios_device/aios_device.xml
Living Room Manufacturer:Denon
Volume control: No
http-get::audio/mpeg:
http-get::audio/x-ms-wma:
http-get::audio/L16;rate=48000;channels=2:
http-get::audio/L16;rate=48000;channels=1:
http-get::audio/L16;rate=44100;channels=2:
http-get::audio/L16;rate=44100;channels=1:
http-get::audio/wav:
http-get::audio/mp3:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
NrTracks: 0
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 GetCurrentState CurrentState out LastChange GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Next InstanceID in A_ARG_TYPE_InstanceID Pause InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Previous InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID X_SetShuffle InstanceID in A_ARG_TYPE_InstanceID Shuffle in X_Shuffle AVTransportURI string AVTransportURIMetaData string A_ARG_TYPE_CurrentState_AVTransport string A_ARG_TYPE_InstanceID ui4 A_ARG_TYPE_ObjectID string A_ARG_TYPE_SeekMode string TRACK_NR TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string AbsoluteCounterPosition ui4 AbsoluteTimePosition string CurrentMediaCategory string CurrentMediaDuration string CurrentPlayMode string NORMAL NORMAL REPEAT_ONE REPEAT_ALL CurrentRecordQualityMode string CurrentTrack ui4 0 0 65535 1 CurrentTrackDuration string CurrentTrackMetaData string CurrentTrackURI string CurrentTransportActions string LastChange string NextAVTransportURI string NextAVTransportURIMetaData string NumberOfTracks ui4 0 0 65535 PlayMode ui4 0 PlaybackStorageMedium string PossiblePlaybackStorageMedia string PossibleRecordQualityModes string PossibleRecordStorageMedia string RecordMediumWriteStatus string RecordStorageMedium string RelativeCounterPosition i4 RelativeTimePosition string TransportPlaySpeed string 1 1 12 -12 TransportState string STOPPED STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING TransportStatus string OK OK ERROR_OCCURRED X_PlayTimeMode string NORMAL NORMAL ELAPSED REMAINED NONE X_Shuffle boolean 0Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-denon-com:device:AiosDevice:1 Living Room Denon http://www.denon.com Denon DRA-800H Aios 4.025 BJN27191106194 uuid:2b02164b-a6bc-145f-0080-0005cdbb4102 8080 urn:schemas-upnp-org:device:MediaRenderer:1 Living Room Denon http://www.denon.com Denon DRA-800H Aios 4.025 uuid:66104dd4-d1be-1aa9-0080-0005cdbb4102 QPlay:1 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/scpd/renderer_dvc/AVTransport.xml /upnp/control/renderer_dvc/AVTransport /upnp/event/renderer_dvc/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/renderer_dvc/ConnectionManager.xml /upnp/control/renderer_dvc/ConnectionManager /upnp/event/renderer_dvc/ConnectionManager urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/scpd/renderer_dvc/RenderingControl.xml /upnp/control/renderer_dvc/RenderingControl /upnp/event/renderer_dvc/RenderingControl urn:schemas-denon-com:device:AiosServices:1 AiosServices Denon http://www.denon.com Denon DRA-800H Aios 4.025 uuid:8b7bcfdc-f678-1a2f-0080-0005cdbb4102 urn:schemas-denon-com:service:ErrorHandler:1 urn:denon-com:serviceId:ErrorHandler /upnp/scpd/AiosServicesDvc/ErrorHandler.xml /upnp/control/AiosServicesDvc/ErrorHandler /upnp/event/AiosServicesDvc/ErrorHandler urn:schemas-denon-com:service:ZoneControl:2 urn:denon-com:serviceId:ZoneControl /upnp/scpd/AiosServicesDvc/ZoneControl.xml /upnp/control/AiosServicesDvc/ZoneControl /upnp/event/AiosServicesDvc/ZoneControl urn:schemas-denon-com:service:GroupControl:1 urn:denon-com:serviceId:GroupControl /upnp/scpd/AiosServicesDvc/GroupControl.xml /upnp/control/AiosServicesDvc/GroupControl /upnp/event/AiosServicesDvc/GroupControl urn:schemas-denon-com:device:ACT-Denon:1 Living Room Denon http://www.denon.com Denon DRA-800H Aios 4.025 BJN27191106194 uuid:ef707f50-d7e5-b94d-fd6d-7c1f00229dfe AIOS:0001 2 1687991063 Thu 2023-06-29 10:17:36 2.98.451 00:05:CD:BB:41:00 en_EU 4 Aios 4.025 1 Production 00:05:CD:BB:41:02 urn:schemas-denon-com:service:ACT:1 urn:denon-com:serviceId:ACT /ACT/SCPD.xml /ACT/control /ACT/event urn:schemas-upnp-org:device:MediaServer:1 Living Room Denon http://www.denon.com Shares User defined folders and files to other Universal Plug and Play media devices. Denon DRA-800H Aios 4.025 BJN27191106194 uuid:44270200-8a1b-dd90-666d-aadb29fb64de True urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /upnp/scpd/ams_dvc/ContentDirectory.xml /upnp/control/ams_dvc/ContentDirectory /upnp/event/ams_dvc/ContentDirectory urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/ams_dvc/ConnectionManager.xml /upnp/control/ams_dvc/ConnectionManager /upnp/event/ams_dvc/ConnectionManagerUPnP devices found : 2
Device #0Living Room UID: uuid:2b02164b-a6bc-145f-0080-0005cdbb4102 Location: http://192.168.1.197:60006/upnp/desc/aios_device/aios_device.xml
Device #1Bureau UID: uuid:de18c7c7-9ee7-1e1e-0080-0005cdb8182e Location: http://192.168.1.111:60006/upnp/desc/aios_device/aios_device.xml
Max. memory for audio buffers: 5300MB
Local Audio Engine:WASAPI
Local devices found : 5
Device #0: Haut-parleurs (Realtek(R) Audio) Manufacturer: Model UID: Haut-parleurs (Realtek(R) Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{2684fae6-6be0-45f7-ac87-2473daf25438}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: 3 - VX2457 (3- AMD High Definition Audio Device) Manufacturer: Model UID: 3 - VX2457 (3- AMD High Definition Audio Device) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{96d92bd5-0448-4588-a323-d19363bb1c00}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: CABLE Input (VB-Audio Virtual Cable) Manufacturer: Model UID: CABLE Input (VB-Audio Virtual Cable) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{a8e41368-d8f1-45e9-bda1-9eba0ebbd555}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: Sortie numérique (Realtek(R) Audio) Manufacturer: Model UID: Sortie numérique (Realtek(R) Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{7e501c9e-3be1-49c0-9494-286438457b31}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #4: 4 - VX2457 (3- AMD High Definition Audio Device) Manufacturer: Model UID: 4 - VX2457 (3- AMD High Definition Audio Device) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{eff61501-9802-4979-bc15-6579f709362a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
