i don’t know while reading again your first post, what you did for a clean install…
my recipy is ![:slight_smile: :slight_smile:](/images/emoji/apple/slight_smile.png?v=9)
If you have Playlists that are important export them first to desktop and
save them in a folder… when A+ is reset, you can re-import them back in A+ menu.
sadly to this day, the folders they were in is not back, you have to do it again…
Before doing this, maybe you should not connect after deleting those files to Roon or others…
install A+ alone with your database… if working, log to Roon or else after ![:slight_smile: :slight_smile:](/images/emoji/apple/slight_smile.png?v=9)
click Show Library Folder and then you’ll have access to the rest forever ![:slight_smile: :slight_smile:](/images/emoji/apple/slight_smile.png?v=9)
Starting for new A+:
Go to the main Library Folder… PrivilegedHelperTools folder…
Trash All the files in that folder (that folder install SysOptimizer)
Go to the main Library Folder…LaunchDaemons folder…
Trash All the files in that folder for Audirvana (SystemOptimizer and prefs files)
Trash All the files in that folder (that is your database of music, back it up!)
trash com.audirvana.Audirvana-Plus.plist in that folder (those are A+ software preferences)
Go to User… Home Folder… Library… Caches… com.audirvana.Audirvana-Plus
trash the files in that folder
Restart MAC just to be sure… This will reset pretty much Audirvana like new.
When choosing library at first it will sync in top right main window under the logo…
LET IT GO, even better don’t try to adjust windows or edit files, even playing music while
it is not finished… you’ll see the progress bar going… Could be long the first time
depending on how large your library is, and MAC is fast or not… go to sleep… then see ![:slight_smile: :slight_smile:](/images/emoji/apple/slight_smile.png?v=9)
