Problems with Cambridge Audio DacMagic Plus
Hello there,
Am new to Audirvana for Windows and am testing the 30 day version. I Instaled it on my Windows 10 pc, everything went fine until I went to connect it to my device. One option was over my network to my tv, the other was 1. to my av amp and 2. to my CA DacMagic Plus. I also had a WASAPI and ASIO option. When I selected ASIO it would only connect to the tv and when I selected WASAPI and my DAC I got sound for a second and then went silent. I tried WASAPI again and selected my av amp and still nothing, I’d rather it sent the signal to the DAC, am new to all this and any help would be great.
Peter
Any help folks, tried everything now and still no sound??
Can you dump the debug info here while connected to the DacMagic?
Hello Bitracer… unfortunately I am not very technically minded and new to all this…how would I do that?
Peter
Hello @PeterD, can you send me a copy of the ā€œDebug Infoā€? You can get it in Audirvana Settings>General>Debug Info
Hello Damien.
Thank you for your help!
Audirvana 3.5.10
SoX
AUTO: D:\Flac CD
Library database path: C:\Users\Admin\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2522MB
Local Audio Engine:WASAPI
Speakers (Cambridge Audio USB Audio 1.0)
Model UID:Speakers (Cambridge Audio USB Audio 1.0)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{bb63ee4f-5f1d-4e03-be74-5db8d13826c1}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
AV Receiver (IntelĀ® Display Audio) Manufacturer:
Model UID:AV Receiver (IntelĀ® Display Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{f6462645-e012-4633-9318-6da399fe37fa}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Device #0: AV Receiver (IntelĀ® Display Audio) Manufacturer: Model UID: AV Receiver (IntelĀ® Display Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f6462645-e012-4633-9318-6da399fe37fa}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0[LG] webOS TV UH770V UID: uuid:cd0801e8-92d9-4f26-40f3-ca868ecbea9a Location: http://192.168.0.24:1536/
Hello @PeterD, i can’t see your DAC selected, does it is connected to your computer?
Hello there… yes it is, there are two options, the amp and the CA DAC, if I select either I still do not get any sound.
Peter
Keep only the DAC connected via USB. Disconnect the other device.
Install the latest CA driver:
You might want to upgrade the firmware too, if you didn’t already:
The other device is my amp, which is connected via phono and HDMI, if I disconnect the HDMI I will not be able to see or use my Windows 10 pc?
Peter
I don’t see your USB DAC in the device found by Audirvana below :point_down:
Its listed here under preferred device
Audirvana 3.5.10
SoX
AUTO: D:\Flac CD
Max. memory for audio buffers: 2664MB
Active Sample Rate: 96kHz
Speakers (Cambridge Audio USB Audio 1.0) Manufacturer:
Model UID:Speakers (Cambridge Audio USB Audio 1.0) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{bb63ee4f-5f1d-4e03-be74-5db8d13826c1}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (Cambridge Audio USB Audio 1.0) Manufacturer: Model UID: Speakers (Cambridge Audio USB Audio 1.0) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{bb63ee4f-5f1d-4e03-be74-5db8d13826c1}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #0[LG] webOS TV UH770V UID: uuid:cd0801e8-92d9-4f26-40f3-ca868ecbea9a Location: http://192.168.0.24:1210/
Hi PeterD!
Follow bitracers advice and update firmware!
BR
BB
