Problems with linux installation for audirvana studio
When you have performed the steps in the pictures you should restart the computer and see if the computer running Audirvāna is visible then in the remote app.
Because you have added Audirvāna then to the applications that should run on booting the computer.
illy@WILLYLINUXMINT:~$ ^[[200~sudo /opt/audirvana/studio/setAsService.sh enable~
sudo: orden no encontrada
willy@WILLYLINUXMINT:~$ sudo /opt/audirvana/studio/setAsService.sh enable
[sudo] contraseña para willy:
Lo siento, pruebe otra vez.
Creating audirvana user
The audirvanaStudio service will run as user audirvana
Installing audirvanaStudio service
willy@WILLYLINUXMINT:~$ sudo /opt/audirvana/studio/setAsService.sh start
Starting audirvanaStudio service
I have this now but dont see the process running
Are you able to follow the steps from my screenshots?
It says it is running. If you open the Remote App on your phone or tablet, and you click ‘select computer’, do you see the computer name? (probably WILLYLINUXMINT)
Sorry for the off-topic. I was surprised to read this thread. I thought Audirvana had a graphical client on Linux. I had seen screenshots of what appeared to be a graphical interface running on Linux. Does Audirvana Studio also not have a connection to last.fm on Linux? What other settings can’t be made in the configuration?
Please, start a new topic.
You need to use the Remote app when you use Linux version of Audirvāna. You will find inside of it all you need to use Audirvāna properly, including the last.fm connection process.
i cant make t work Allo with roopie , there is no recognized by audirvana on tne windows machine , is there a problem with roniee? or I should install another OS on the Rpi?
Do you use RopieeeXL?
