Hi all,
I have many versions of the same albums and I selected the versions that sounded better, now I need to move them to a different HD, how can I find in the HD the selected ones from “My music” to export them?
Thank you
Welcome @huho ,
Maybe I am misunderstanding something, but can’t you simply use Finder (Mac) or File Explorer (Windows) to locate and move the files to another HD? After that simply re-scanning your library in Audirvana should do the trick.
Hi,
Sorry I was not clear. I’m using a Mac, and many albums have the same name, but they have different mastering, after spending quite some time selecting (My music) the ones that sounds better to me, now I want to move those to a different HD or delete the ones I don’t want. It’s impossible to find the selected albums just browsing through the HD. I would like to know if there is a way to find them through Audirvana.
Thank you
Look at my last picture, click a song there and look at the path on the right… that is where the song is on your hard drive
Great! Thank you!
