I try to describe the problem that I keep on encountering ;
I play Audirvana via Pc and usb to dac, Then I decide to switch to NAS. I close the app on Pc I start the Remote, which finds the Nas, but it will not connect, Therefore I close the Remote app and reopen it few times, all of the sudden it asks me to login, which I do, then everything appears on the screen as usual, I then need to select the upnp dac in Setting, then I start to play something but it will not play. I close and reopen the remote but it would not play.
To make the remote play I need to enter in the NAS web-controller and stop the App on the Nas and then restart it. The Remote after that starts playing.
All this opening and closing is a real nuisance but why the app on Qnap must be restarted manually?
Can you go on tour QNAP and look at the logs generated by Audirvāna? You should have a mention on where it is located when you click on the Audirvāna icon on QNAP GUI.
I started the qnap, went into the webcontroller clicked on the qnap app log
============= Started Logging, Audirvana Studio 2.8.1.3 linux =============
2024-04-29 16:09:23.868 [info]: No language set in settings, using system language: en_US.UTF-8
2024-04-29 16:09:23.919 [info]: RemoteServer: Server started and advertised on port 35413
2024-04-29 16:09:24.698 [info]: UPnP stack initialized using default interface
2024-04-29 16:09:24.898 [info]: UPnP web server started on 192.168.0.150:49152
2024-04-29 16:09:24.901 [error]: UPnP select device: can’t find the device Weiss Engineering Ltd. DAC501-4ch with UID: uuid:00001c6a-0dac-0501-0437-1442fcc34da3
2024-04-29 16:09:25.027 [error]: UPnP: Error obtaining device description from http://192.168.0.41:9080 – error = -107
2024-04-29 16:09:26.359 [error]: UPnP: Error obtaining device description from http://192.168.0.41:9080 – error = -107
2024-04-29 16:09:26.360 [error]: UPnP: Error obtaining device description from http://192.168.0.41:9080 – error = -107
2024-04-29 16:09:27.357 [error]: UPnP: Error obtaining device description from http://192.168.0.41:9080 – error = -107
2024-04-29 16:09:27.488 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience_ The Dramatist Vol. II/.@_thumb/s10001 - Ballade #1 in G Minor, Op. 23.flac error = 4
2024-04-29 16:09:27.488 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10001 - Ballade #1 in G Minor, Op. 23.flac
2024-04-29 16:09:27.490 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10002 - Ballade #2 in F Major, Op. 38.flac error = 4
2024-04-29 16:09:27.490 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10002 - Ballade #2 in F Major, Op. 38.flac
2024-04-29 16:09:27.507 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10003 - Ballade #3 in a Flat Major, Op. 47.flac error = 4
2024-04-29 16:09:27.507 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10003 - Ballade #3 in a Flat Major, Op. 47.flac
2024-04-29 16:09:27.511 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10004 - Ballade #4 in F Minor, Op. 52.flac error = 4
2024-04-29 16:09:27.511 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10004 - Ballade #4 in F Minor, Op. 52.flac
2024-04-29 16:09:27.512 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10005 - Scherzo #1 in B Minor, Op. 20.flac error = 4
2024-04-29 16:09:27.512 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10005 - Scherzo #1 in B Minor, Op. 20.flac
2024-04-29 16:09:27.513 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10006 - Scherzo #1 in B Minor, Op. 31.flac error = 4
2024-04-29 16:09:27.513 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10006 - Scherzo #1 in B Minor, Op. 31.flac
2024-04-29 16:09:27.514 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10007 - Scherzo #3 in C-Sharp Minor, Op. 39.flac error = 4
2024-04-29 16:09:27.514 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10007 - Scherzo #3 in C-Sharp Minor, Op. 39.flac
2024-04-29 16:09:27.515 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10008 - Scherzo #4 in E Major.flac error = 4
2024-04-29 16:09:27.515 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10008 - Scherzo #4 in E Major.flac
2024-04-29 16:09:27.561 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s80007 - Scherzo #3 in C-Sharp Minor, Op. 39.flac error = 4
2024-04-29 16:09:27.561 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@__thumb/s80007 - Scherzo #3 in C-Sharp Minor, Op. 39.flac
2024-04-29 16:09:31.420 [error]: Chromecast device scanner: client failure
2024-04-29 16:09:31.420 [error]: Avahi Client failure: Daemon connection failed
Audirvana remote indicates “no computer recognized etc…”
I then close the remote app, shut down the qnap app and then restart, then start the remote app which now connects the log of the qnap app is:
2024-04-29 16:18:53.332 [info]: No language set in settings, using system language: en_US.UTF-8
2024-04-29 16:18:53.380 [info]: RemoteServer: Server started and advertised on port 39257
2024-04-29 16:18:54.210 [info]: UPnP stack initialized using default interface
2024-04-29 16:18:54.228 [error]: UPnP: Error obtaining device description from http://192.168.0.41:9080 – error = -107
2024-04-29 16:18:54.411 [info]: UPnP web server started on 192.168.0.150:49152
2024-04-29 16:18:55.358 [error]: UPnP: Error obtaining device description from http://192.168.0.41:9080 – error = -107
2024-04-29 16:18:56.021 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience_ The Dramatist Vol. II/.@_thumb/s10001 - Ballade #1 in G Minor, Op. 23.flac error = 4
2024-04-29 16:18:56.021 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10001 - Ballade #1 in G Minor, Op. 23.flac
2024-04-29 16:18:56.022 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10002 - Ballade #2 in F Major, Op. 38.flac error = 4
2024-04-29 16:18:56.022 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10002 - Ballade #2 in F Major, Op. 38.flac
2024-04-29 16:18:56.023 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10003 - Ballade #3 in a Flat Major, Op. 47.flac error = 4
2024-04-29 16:18:56.023 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10003 - Ballade #3 in a Flat Major, Op. 47.flac
2024-04-29 16:18:56.023 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10004 - Ballade #4 in F Minor, Op. 52.flac error = 4
2024-04-29 16:18:56.023 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10004 - Ballade #4 in F Minor, Op. 52.flac
2024-04-29 16:18:56.024 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10005 - Scherzo #1 in B Minor, Op. 20.flac error = 4
2024-04-29 16:18:56.024 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10005 - Scherzo #1 in B Minor, Op. 20.flac
2024-04-29 16:18:56.024 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10006 - Scherzo #1 in B Minor, Op. 31.flac error = 4
2024-04-29 16:18:56.024 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10006 - Scherzo #1 in B Minor, Op. 31.flac
2024-04-29 16:18:56.025 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10007 - Scherzo #3 in C-Sharp Minor, Op. 39.flac error = 4
2024-04-29 16:18:56.025 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10007 - Scherzo #3 in C-Sharp Minor, Op. 39.flac
2024-04-29 16:18:56.026 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10008 - Scherzo #4 in E Major.flac error = 4
2024-04-29 16:18:56.026 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s10008 - Scherzo #4 in E Major.flac
2024-04-29 16:18:56.032 [error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@_thumb/s80007 - Scherzo #3 in C-Sharp Minor, Op. 39.flac error = 4
2024-04-29 16:18:56.032 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Ashkenazy/The Chopin Experience The Dramatist Vol. II/.@__thumb/s80007 - Scherzo #3 in C-Sharp Minor, Op. 39.flac
2024-04-29 16:19:32.540 [error]: UPnP Error 401 setting play mode to normal
2024-04-29 16:19:32.546 [error]: UPnP Error 401 getting current transport actions
2024-04-29 16:19:32.546 [warning]: UPnP GetCurrentTransportActions error => setting default actions
I have tried it now to reinstall qnap app and it now seems to work properly.
Now it is getting stranger and stranger… I have deleted and reinstall many times the qnap app and the remote, restarted the qnap etc, certain cd are not loaded any longer. BUT if i go to pc which is retrieving the cd from the NAS, the cd is there and can be seen also from the remote app linked to the pc.
But there is no way to find it if I use the qnap app. I looked also at folder view and the cd is not there… but I can see it from pc no problem
When the remote app is linking to qnap via qnap app it reads 4475 tracks vs 4789 when the pc is used to play music located on the qnap nas
How is possible that the Qnap app has “lost” over 300 tracks?
In the logs of the QNAP, do you see any errors?
Yes I get error like this one:
[error]: Error reading FLAC file metadata: file=/share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Horowitz/The Celebrated Scarlatti Recordings 1962-73/.@_thumb/s80018 - Sonata in C Min, K303 (L9) Allegro.flac error = 4
2024-05-07 16:29:16.798 [warning]: Local Library Sync: Not synching unreadable file /share/CACHEDEV2_DATA/multimediale/Musica/CDpapa/Vladimir Horowitz/The Celebrated Scarlatti Recordings 1962-73/.@_thumb/s80018 - Sonata in C Min, K303 (L9) Allegro.flac"
But I can play the above track no problems. The tracks that cannot be found are not in the error list,
Is it normal that after having unistall the Qnap app and reinstall it again in the CACHE DEV- 2 I find the "multimediale/musica?
I would expect such CACHE DEV-2 to be empty , and to appear only after I have added my folder “multimediale/musica”
Since I have the Qnap app on m2 ssd card, I was able to cancel the m2 ssd volume and reinstall everything from the start. Unfortunately this fresh start did not help to locate the" lost tracks " and over 300 tracks cannot be located by the Qnap app while they are found from the PC app (reading it from the NAS)
After the clean installation I get this error:
: ============= Previous crash log =============
2024-05-09 15:14:32.632 [critical]: Audirvana Studio 2.8.1.3 crash log
2024-05-09 15:14:32.632 [critical]: Date: 2024-5-9 13:14:10
2024-05-09 15:14:32.632 [critical]: Signal: SIGSEGV
2024-05-09 15:14:32.632 [critical]: /share/CACHEDEV1_DATA/.qpkg/audirvana-studio/audirvanaStudio(+0xfd72dc)[0x55dab22042dc]
2024-05-09 15:14:32.632 [critical]: /lib64/libpthread.so.0(+0x106f0)[0x7f0f44c4b6f0]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libdbus-1.so.3(+0x274dd)[0x7f0f3fa694dd]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libdbus-1.so.3(+0x134b6)[0x7f0f3fa554b6]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libdbus-1.so.3(dbus_message_get_reply_serial+0x21)[0x7f0f3fa59af1]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libdbus-1.so.3(+0xbe0e)[0x7f0f3fa4de0e]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libdbus-1.so.3(+0x22e6c)[0x7f0f3fa64e6c]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libdbus-1.so.3(+0x237a6)[0x7f0f3fa657a6]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libdbus-1.so.3(+0x23ea2)[0x7f0f3fa65ea2]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libdbus-1.so.3(+0x22c28)[0x7f0f3fa64c28]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libdbus-1.so.3(+0xd454)[0x7f0f3fa4f454]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libdbus-1.so.3(+0xde29)[0x7f0f3fa4fe29]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libdbus-1.so.3(dbus_connection_send_with_reply_and_block+0xc5)[0x7f0f3fa50415]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libdbus-1.so.3(dbus_bus_register+0x10a)[0x7f0f3fa4c52a]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libdbus-1.so.3(+0xa7bf)[0x7f0f3fa4c7bf]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libavahi-client.so.3(+0x4f7a)[0x7f0f42132f7a]
2024-05-09 15:14:32.632 [critical]: /usr/lib/libavahi-client.so.3(avahi_client_new+0x16c)[0x7f0f4213310f]
2024-05-09 15:14:32.632 [critical]: /share/CACHEDEV1_DATA/.qpkg/audirvana-studio/audirvanaStudio(+0x1e9390)[0x55dab1416390]
2024-05-09 15:14:32.632 [critical]: /share/CACHEDEV1_DATA/.qpkg/audirvana-studio/audirvanaStudio(+0x1ec413)[0x55dab1419413]
2024-05-09 15:14:32.632 [critical]: /share/CACHEDEV1_DATA/.qpkg/audirvana-studio/audirvanaStudio(+0x1ae3df)[0x55dab13db3df]
2024-05-09 15:14:32.632 [critical]: /lib64/libpthread.so.0(+0xddeb)[0x7f0f44c48deb]
2024-05-09 15:14:32.632 [critical]: /share/CACHEDEV1_DATA/.qpkg/audirvana-studio/audirvanaStudio(+0x1ae662)[0x55dab13db662]
2024-05-09 15:14:32.632 [critical]: /share/CACHEDEV1_DATA/.qpkg/audirvana-studio/audirvanaStudio(+0x1ec17c)[0x55dab141917c]
2024-05-09 15:14:32.632 [critical]: /share/CACHEDEV1_DATA/.qpkg/audirvana-studio/audirvanaStudio(+0x1ebfda)[0x55dab1418fda]
2024-05-09 15:14:32.632 [critical]: /share/CACHEDEV1_DATA/.qpkg/audirvana-studio/audirvanaStudio(+0x1ae4e8)[0x55dab13db4e8]
2024-05-09 15:14:32.632 [critical]: /share/CACHEDEV1_DATA/.qpkg/audirvana-studio/audirvanaStudio(+0x1adeac)[0x55dab13daeac]
2024-05-09 15:14:32.632 [critical]: /share/CACHEDEV1_DATA/.qpkg/audirvana-studio/audirvanaStudio(+0xfd4898)[0x55dab2201898]
2024-05-09 15:14:32.632 [critical]: /lib64/libc.so.6(__libc_start_main+0xf0)[0x7f0f412d4810]
2024-05-09 15:14:32.632 [critical]: /share/CACHEDEV1_DATA/.qpkg/audirvana-studio/audirvanaStudio(+0x1690e5)[0x55dab13960e5]
2024-05-09 15:14:32.632 [critical]: Fault location: 0x7FFDADCC5C90
I have installed the new version 2.8.1.7 and most of the errors i have reported have disappeared, nevertheless I still miss over 300 tracks on the Qnap app which are present if I use the PC app. The problem seem to be that folders containing wma tracks are not loaded.
Could you please verify that on your side?
WMA is a Microsoft proprietary format, that’s why its codec is available only on Windows.
