Hello again. Wondering if this question is in the wrong forum? @Antoine I see you actively responding to other posts, but not this one. I assume I can’t be the only one with this problem. Qobuz does sound best running through Audirvana. Trying to listen to TOOL, Lateralus, first song playing upsampled from 96 to 192 and it stopped 7 seconds short. Here’s the debug info:
Audirvana 3.5.45
SoX with 2x upsampling
Bandwidth at 0dB = 87.2982
Phase = 65
Sync list: 0 folders
Library database path: C:\Users\brian\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4434MB
Local Audio Engine:WASAPI
Digital Output (Chord Async USB 44.1kHz-768kHz)
Model UID:Digital Output (Chord Async USB 44.1kHz-768kHz)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{af2adaa5-ded2-406d-a734-067a28e682d6}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 32bits Integer, 8 bytes per frame 192kHz
Active Sample Rate: 192kHz
Digital Output (Chord Async USB 44.1kHz-768kHz) Manufacturer:
Model UID:Digital Output (Chord Async USB 44.1kHz-768kHz) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{af2adaa5-ded2-406d-a734-067a28e682d6}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 768kHz
Local devices found : 3
Device #0: Digital Output (Chord Async USB 44.1kHz-768kHz) Manufacturer: Model UID: Digital Output (Chord Async USB 44.1kHz-768kHz) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{af2adaa5-ded2-406d-a734-067a28e682d6}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (Realtek® Audio) Manufacturer: Model UID: Speakers (Realtek® Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{9969b082-ccc1-44ad-ab80-52272dec10dd}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Speakers (USB Audio Device) Manufacturer: Model UID: Speakers (USB Audio Device) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ccfe1798-27e1-44f7-9f03-a21f4b869b75}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 6
Device #0Denon AVR-X4500H UID: uuid:b49e4852-2b85-1cdd-0080-00067837adb2 Location: http://192.168.1.4:60006/upnp/desc/aios_device/aios_device.xml
Device #1UBP-X1100ES UID: uuid:00000000-0000-1010-8000-38184ca25a53 Location: http://192.168.1.2:52323/dmr.xml
Device #2Denon AVR-X4500H UID: uuid:effbf7f6-dadc-1a76-0080-00067837adb2 Location: http://192.168.1.4:60006/upnp/desc/aios_device/aios_device.xml
Device #3Denon AVR-X4500H UID: uuid:d535a882-e305-173a-0080-00067837adb2 Location: http://192.168.1.4:60006/upnp/desc/aios_device/aios_device.xml
Device #4Denon AVR-X4500H UID: uuid:2cbe445f-e547-264e-2388-2cadc1b83fe8 Location: http://192.168.1.4:60006/upnp/desc/aios_device/aios_device.xml
Device #5Denon AVR-X4500H UID: uuid:c6f243af-aa0f-6642-cf62-77a7088b4dc7 Location: http://192.168.1.4:60006/upnp/desc/aios_device/aios_device.xml
