Nella mia homepage del programmma Studio non vedo più Qoboz, anche nella app
del telefono android Qobuz è sparito.
Come posso risolvere?
Grazie
si, ho anche provato a riavviare il computer.
Audirvana Studio 2.6.6 (20606)
Windows 10 (19045) with 8GB physical RAM
Connected account of : Lorenzo Colombo Canepa
Available network interfaces:
Ethernet ({a480c5b5-8ddd-4d4f-8784-ac4781f82c6f}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Max allowed volume: 83.3488
Sync list: 3 folders
Manual: (OFFLINE) D:
AUTO: F:
AUTO: I:\Media\Musica
Library database path: E:\Users\AudirvanaDatabase.sqlite
Tracks with no MBID: 43809
Listening on 192.168.1.104 on port 63070
TIDAL: Connected as PREMIUM
Max. memory for audio buffers: 4096MB
Uscita digitale (GOLD NOTE USB-DAC Driver 1.0.62)
Model UID:USB\VID_16D0&PID_0D01&REV_0107
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{c2d7a782-febf-4a6b-a2d3-9868f78b81b3}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Selected device:Uscita digitale (GOLD NOTE USB-DAC Driver 1.0.62)
Manufacturer: Akamai
Model name: GOLD NOTE USB-DAC
Model UID: USB\VID_16D0&PID_0D01&REV_0107
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{c2d7a782-febf-4a6b-a2d3-9868f78b81b3}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x16d0
USB Product ID: 0x0d01
Kernel Streaming capable
DSD via PCM 1.0
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
Local devices found : 3
Device #0: Uscita digitale (GOLD NOTE USB-DAC Driver 1.0.62)
Device #1: Altoparlanti (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_18496893&REV_1003
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{2e59b272-b73a-4a09-a320-73f667ce0a13}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: AMD HDMI Output (AMD High Definition Audio Device)
Manufacturer: Advanced Micro Devices
Model UID: HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1002
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f30f70fe-c847-4f29-9351-e4bb071746d1}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Ok, that’s strange. Let’s see your logs.
Can you go into the Audirvāna settings and in the My Account section? You will see a ‘Start Log Session’ button, click on it, and then reproduce your issue. After you reproduce it, click 'Stop Log Session’ and send me the log file you can find by clicking on the button ‘Open Log Folder’ at support@audirvana.com.
I have the same problem with the new version.
I updated to the latest version two days ago. When I ran AS for the first time, I had no problems with Qobuz. But today, although the AS setting page shows Qobuz connected, Qobuz is completely missing in the AS.
Ho disconnesso e riconnesso qobuz ora funziona tutto.
devo inviarvi i log?
No need. If the disconnection/reconnection worked, then you are good to go
Grazie per l’offerta di supporto. Ho appena provato il metodo indicato nel suo messaggio, ma il problema persiste.
Thank you for your offer of support. I just tried the method you mentioned in your message, but the problem persists.
Ok grazie per l’aiuto
Can you please send me the logs of Audirvāna Studio?
I wrote a reply above by misinterpreting Lorenzo10’s message. But the same problem persists in me. Disconnection/connection method did not work for me. The problem continues.
I received it, I will review it as soon as possible.
Hi Antoine,
Thank you for your reply e-mail. I did not see an explanation about the solution in your e-mail that you stated that you identified the problem.
Qobuz desktop application works as it should, but you say that there is an error when you connect to Qobuz via AS application. Who will solve this problem, Qobuz team or Audirvana team?
Thank you
When you are connecting to their Desktop app, you are using the internal API of Qobuz, which uses a different API endpoint from ours. Since we are a third-party app, we have a dedicated API like any other Qobuz partner. Therefore since the issue is API-related, there is nothing we can do for the time being and action needs to be taken by the Qobuz API team.
