Qobuz metadata on remote
Why can’t I see the same Qobuz metadata on the Android remote that I see on the AS desktop app i.e. record label and release date?
I guess you mean on mobile. If the app is installed on a tablet that info is visible
You are correct. I was referring to mobile. Thank you for pointing that out.
My educated guess is that on a smaller screen less information can be shown.
Makes perfect sense. Thank you…
