Effectivement.
Voici l’intégral.
Audirvana Studio 1.8.1 (10801)
macOS 11.6 with 16GB physical RAM
Connected account:
AUTO: /Users/fabriceasl/Desktop/MUSIC
Library database path: /Users/fabriceasl/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 51540
Qobuz: Login failed
APPLE, INC. MUSIQUESALON (AIRPLAY)
Model UID:83:7D:F5:2B:B7:D7-644490413523-airplay
ID 0x5f MusiqueSalon (AirPlay)
Manufacturer: Apple, Inc.
Model Name: Apple, Inc. MusiqueSalon (AirPlay)
Model UID: 83:7D:F5:2B:B7:D7-644490413523-airplay
1 available sample rates up to 44100Hz
0 Airplay connected device(s):
Stream ID 0x60 2 channels starting at 1
1 virtual formats:
1 physical formats
Local devices found : 5
Device #0: ID 0x5f MusiqueSalon (AirPlay) Manufacturer: Apple, Inc. Model UID: 83:7D:F5:2B:B7:D7-644490413523-airplay UID: 83:7D:F5:2B:B7:D7-644490413523-airplay Model Name: Apple, Inc. MusiqueSalon (AirPlay)
Device #1: ID 0x55 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:94 UID: AppleHDAEngineOutput:1B,0,1,1:0 Model Name: Apple Inc. Sortie intégrée
Device #2: ID 0x43 Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0 Model Name: ma++ ingalls for Cycling '74 Soundflower (2ch)
Device #3: ID 0x30 Apowersoft Audio Device Manufacturer: Apowersoft Music contributors Model UID: com.apowersoft.audioModelDevice UID: com.apowersoft.audioDevice Model Name: Apowersoft Music contributors Apowersoft Audio Device
Device #4: ID 0x3c ZoomAudioDevice Manufacturer: zoom.us Model UID: zoom.us.zoomaudiodevice UID: zoom.us.zoomaudiodevice.001 Model Name: zoom.us ZoomAudioDevice
UPnP devices found : 0[quote=“Fasa, post:1, topic:30579, full:true”]
Bonjour,
Qobuz n’apparait plus dans Audirvana.
Un message d’erreur lors du chargement de Qobuz dans Audirvana.
Qobuz fonctionne sur mon mac :
MacBook Pro (Retina, 15 pouces, fin 2013)
2 GHz Intel Core i7 quatre cœurs
16 Go 1600 MHz DDR3
En revanche j’ai changé le mot de passe de Qobuz !
Merci de m’éclairer.
Fasa.
[/quote]
Merci
