Is there any way to sort the Qobuz purchased view between Artist, Album and purchased date as with the native Qobuz App.
By default, I think it’s sorted as purchased date in Audirvāna Studio, can you confirm?
Yes I can confirm that appears to be the case.
For the moment, this is the default sorting, but we need to add more sorting option for views like this. It also relies on Qobuz API so I need check with them if it’s possible.
Thank you.
