Qobuz wont play but Tidal will
As of today I click play in quboz and it hangs saying opening file and then says unable to play file. I tried disconnecting, closing and reconnecting but same thing. uninstall re install same thing. Tidal works fine on this machine.
On my other computer quboz is working fine through AS…
Any one else having this?
Audirvana Studio 2.7.0 (20700)
Windows 11 (22621) with 16GB physical RAM
Connected account of : Jason Texel
Available network interfaces:
Ethernet 2 ({fc942996-50c1-4cd8-87f4-0ec77d705f24}) is PUBLIC
Active profile types: all
Private profile:
Firewall: disabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: disabled
Inbound: blocked
Outbound: allowed
AUTO: C:\Users\Admin\Music
Library database path: C:\Users\Admin\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Fingerprinting track 77/909 : C:\Users\Admin\Music\Music\timeMeasurementClick.wav
Listening on 172.16.0.50 on port 50182
TIDAL: Connected as HiFi Plus
Max. memory for audio buffers: 8192MB
Speakers (SRC-DX)
Model UID:USB\VID_2FC6&PID_6013&REV_0201&MI_00
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{426e46c2-1d27-4e14-8b6a-33145a9efc66}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Selected device:Speakers (SRC-DX)
Manufacturer: Microsoft
Model name: SRC-DX
Model UID: USB\VID_2FC6&PID_6013&REV_0201&MI_00
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{426e46c2-1d27-4e14-8b6a-33145a9efc66}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x2fc6
USB Product ID: 0x6013
Kernel Streaming capable
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 768kHz
Device #0: Speakers (SRC-DX)
Model name: SRC-DX
UPnP devices found : 1
Device #0: [LG] webOS TV OLED77C1PUB
UID: uuid:76379775-f0e9-feda-bbc8-75bd53b881ff
Manufacturer: LG Electronics.
Model name: LG TV
Local files play fine BTW.
Try logging out completely from Qobuz, and then log back in.
Thanks. I did try that. Also logging out of AS and back in. And finally remove AS and reinstall. Still wont play quboz but tidal and local are fine… dang it
Here is the log files for when i try and play a quboz file, i can login to quboz and browse fine the files just wont play, guessing thats the error 400
2024-03-01 16:46:31.907 [info]: ============= Started Logging, Audirvana Studio 2.7.0 (20700) =============
2024-03-01 16:46:33.560 [error]: Not logged to Audirvana account: need to sign in
2024-03-01 16:46:34.767 [info]: RemoteServer: Server started and advertised on port 49778
2024-03-01 16:46:57.966 [info]: UPnP stack initialized using default interface
2024-03-01 16:46:58.173 [info]: UPnP web server started on 172.16.0.50:49152
2024-03-01 16:47:30.749 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:47:31.210 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:47:31.612 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:47:31.980 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:47:32.423 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:47:32.866 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:47:33.381 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:47:33.819 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:47:34.165 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:47:34.511 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:47:34.917 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:47:35.402 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:47:35.794 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:47:36.136 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:47:36.142 [error]: Unable to stop audio client: -2004287487
2024-03-01 16:47:45.835 [error]: AudioFileLoader: Error -2147417825 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%201-Audio.wav
2024-03-01 16:47:45.840 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 1-Audio.wav
2024-03-01 16:48:04.311 [error]: VST new user location scan error C:\Users\Admin\AppData\Local\Programs\Common\VST3: unable to enumerate files
2024-03-01 16:48:24.960 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2010-Audio.wav
2024-03-01 16:48:24.960 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 10-Audio.wav
2024-03-01 16:48:25.396 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2011-Audio.wav
2024-03-01 16:48:25.396 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 11-Audio.wav
2024-03-01 16:48:26.117 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2012-Audio.wav
2024-03-01 16:48:26.117 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 12-Audio.wav
2024-03-01 16:48:26.999 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2013-Audio.wav
2024-03-01 16:48:26.999 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 13-Audio.wav
2024-03-01 16:48:28.966 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2014-Audio.wav
2024-03-01 16:48:28.966 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 14-Audio.wav
2024-03-01 16:48:32.296 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2015-Audio.wav
2024-03-01 16:48:32.296 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 15-Audio.wav
2024-03-01 16:48:34.226 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2016-Audio.wav
2024-03-01 16:48:34.226 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 16-Audio.wav
2024-03-01 16:49:01.204 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2017-Audio.wav
2024-03-01 16:49:01.204 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 17-Audio.wav
2024-03-01 16:49:03.901 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2018-Audio.wav
2024-03-01 16:49:03.902 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 18-Audio.wav
2024-03-01 16:49:03.915 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:49:04.269 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:49:04.654 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:49:05.101 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:49:05.475 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:49:05.832 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:49:06.196 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:49:06.540 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:49:06.617 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2019-Audio.wav
2024-03-01 16:49:06.617 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 19-Audio.wav
2024-03-01 16:49:06.914 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:49:07.269 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:49:07.623 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:49:07.969 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:49:08.322 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:49:08.678 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:49:10.730 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%202-Audio.wav
2024-03-01 16:49:10.730 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 2-Audio.wav
2024-03-01 16:49:17.401 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2020-Audio.wav
2024-03-01 16:49:17.401 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 20-Audio.wav
2024-03-01 16:49:27.573 [error]: AudioFileLoader: Error -2147417825 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2021-Audio.wav
2024-03-01 16:49:27.573 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 21-Audio.wav
2024-03-01 16:49:50.895 [error]: AudioFileLoader: Error -2147417825 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2022-Audio.wav
2024-03-01 16:49:50.895 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 22-Audio.wav
2024-03-01 16:50:05.818 [error]: AudioFileLoader: Error -2147417825 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2023-Audio.wav
2024-03-01 16:50:05.818 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 23-Audio.wav
2024-03-01 16:50:24.310 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2024-Audio.wav
2024-03-01 16:50:24.310 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 24-Audio.wav
2024-03-01 16:50:33.692 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2025-Audio.wav
2024-03-01 16:50:33.692 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 25-Audio.wav
2024-03-01 16:50:39.270 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2026-Audio.wav
2024-03-01 16:50:39.270 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 26-Audio.wav
2024-03-01 16:50:46.504 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2027-Audio.wav
2024-03-01 16:50:46.504 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 27-Audio.wav
2024-03-01 16:50:46.766 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2028-Audio.wav
2024-03-01 16:50:46.767 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 28-Audio.wav
2024-03-01 16:50:46.989 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2029-Audio.wav
2024-03-01 16:50:46.989 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 29-Audio.wav
2024-03-01 16:50:47.251 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%203-Audio.wav
2024-03-01 16:50:47.251 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 3-Audio.wav
2024-03-01 16:50:47.612 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2030-Audio.wav
2024-03-01 16:50:47.612 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 30-Audio.wav
2024-03-01 16:50:47.838 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2031-Audio.wav
2024-03-01 16:50:47.838 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 31-Audio.wav
2024-03-01 16:50:48.065 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%204-Audio.wav
2024-03-01 16:50:48.065 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 4-Audio.wav
2024-03-01 16:50:48.291 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%205-Audio.wav
2024-03-01 16:50:48.291 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 5-Audio.wav
2024-03-01 16:50:48.645 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%206-Audio.wav
2024-03-01 16:50:48.645 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 6-Audio.wav
2024-03-01 16:50:48.870 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%207-Audio.wav
2024-03-01 16:50:48.870 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 7-Audio.wav
2024-03-01 16:50:49.101 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%208-Audio.wav
2024-03-01 16:50:49.101 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 8-Audio.wav
2024-03-01 16:50:49.393 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%209-Audio.wav
2024-03-01 16:50:49.393 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 9-Audio.wav
2024-03-01 16:50:49.673 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%20A-Reverb.wav
2024-03-01 16:50:49.673 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test A-Reverb.wav
2024-03-01 16:50:49.899 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%20B-Delay.wav
2024-03-01 16:50:49.899 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test B-Delay.wav
2024-03-01 16:50:50.123 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test.wav
2024-03-01 16:50:50.123 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test_31 band test.wav
2024-03-01 16:50:58.668 [info]: AudioFingerprinting: Starting analysis with file C:\Users\Admin\Music\USETHISPink_PN_64k_Full
-12_dBFS_48.0k_Float_LR.wav
2024-03-01 16:53:41.496 [info]: ============= Started Logging, Audirvana Studio 2.7.0 (20700) =============
2024-03-01 16:53:48.342 [info]: RemoteServer: Server started and advertised on port 49998
2024-03-01 16:53:48.752 [info]: UPnP stack initialized using default interface
2024-03-01 16:53:48.958 [info]: UPnP web server started on 172.16.0.50:49152
2024-03-01 16:53:50.819 [error]: VST new user location scan error C:\Users\Admin\AppData\Local\Programs\Common\VST3: unable to enumerate files
2024-03-01 16:53:58.513 [info]: AudioFingerprinting: Starting analysis with file C:\Users\Admin\Music\Faith (Deluxe) [176_4kHz Ā· 24bit]\15 - Demeanor.flac
2024-03-01 16:54:06.619 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%201-Audio.wav
2024-03-01 16:54:06.619 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 1-Audio.wav
2024-03-01 16:54:06.830 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2010-Audio.wav
2024-03-01 16:54:06.830 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 10-Audio.wav
2024-03-01 16:54:12.420 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2011-Audio.wav
2024-03-01 16:54:12.421 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 11-Audio.wav
2024-03-01 16:54:14.076 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2012-Audio.wav
2024-03-01 16:54:14.076 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 12-Audio.wav
2024-03-01 16:54:15.527 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2013-Audio.wav
2024-03-01 16:54:15.527 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 13-Audio.wav
2024-03-01 16:54:16.247 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2014-Audio.wav
2024-03-01 16:54:16.247 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 14-Audio.wav
2024-03-01 16:54:16.433 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2015-Audio.wav
2024-03-01 16:54:16.433 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 15-Audio.wav
2024-03-01 16:54:18.438 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2016-Audio.wav
2024-03-01 16:54:18.438 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 16-Audio.wav
2024-03-01 16:54:20.210 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2017-Audio.wav
2024-03-01 16:54:20.210 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 17-Audio.wav
2024-03-01 16:54:20.403 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2018-Audio.wav
2024-03-01 16:54:20.403 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 18-Audio.wav
2024-03-01 16:54:21.817 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2019-Audio.wav
2024-03-01 16:54:21.817 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 19-Audio.wav
2024-03-01 16:54:23.788 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%202-Audio.wav
2024-03-01 16:54:23.788 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 2-Audio.wav
2024-03-01 16:54:26.852 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2020-Audio.wav
2024-03-01 16:54:26.852 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 20-Audio.wav
2024-03-01 16:54:28.176 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2021-Audio.wav
2024-03-01 16:54:28.176 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 21-Audio.wav
2024-03-01 16:54:28.361 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2022-Audio.wav
2024-03-01 16:54:28.361 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 22-Audio.wav
2024-03-01 16:54:31.317 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2023-Audio.wav
2024-03-01 16:54:31.317 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 23-Audio.wav
2024-03-01 16:54:32.234 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2024-Audio.wav
2024-03-01 16:54:32.234 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 24-Audio.wav
2024-03-01 16:54:32.417 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2025-Audio.wav
2024-03-01 16:54:32.417 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 25-Audio.wav
2024-03-01 16:54:33.685 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2026-Audio.wav
2024-03-01 16:54:33.685 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 26-Audio.wav
2024-03-01 16:54:36.665 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2027-Audio.wav
2024-03-01 16:54:36.665 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 27-Audio.wav
2024-03-01 16:54:38.572 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2028-Audio.wav
2024-03-01 16:54:38.572 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 28-Audio.wav
2024-03-01 16:54:40.733 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2029-Audio.wav
2024-03-01 16:54:40.733 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 29-Audio.wav
2024-03-01 16:54:40.925 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%203-Audio.wav
2024-03-01 16:54:40.925 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 3-Audio.wav
2024-03-01 16:54:43.751 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2030-Audio.wav
2024-03-01 16:54:43.751 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 30-Audio.wav
2024-03-01 16:55:26.292 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%2031-Audio.wav
2024-03-01 16:55:26.292 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 31-Audio.wav
2024-03-01 16:55:27.758 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%204-Audio.wav
2024-03-01 16:55:27.758 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 4-Audio.wav
2024-03-01 16:55:31.866 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%205-Audio.wav
2024-03-01 16:55:31.866 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 5-Audio.wav
2024-03-01 16:55:31.867 [debug]: Local Library Sync: Synching new/modified file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 6-Audio.wav
2024-03-01 16:55:33.899 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%206-Audio.wav
2024-03-01 16:55:33.899 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 6-Audio.wav
2024-03-01 16:55:33.899 [debug]: Local Library Sync: Synching new/modified file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 7-Audio.wav
2024-03-01 16:55:37.920 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%207-Audio.wav
2024-03-01 16:55:37.920 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 7-Audio.wav
2024-03-01 16:55:37.920 [debug]: Local Library Sync: Synching new/modified file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 8-Audio.wav
2024-03-01 16:55:39.452 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%208-Audio.wav
2024-03-01 16:55:39.452 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 8-Audio.wav
2024-03-01 16:55:39.452 [debug]: Local Library Sync: Synching new/modified file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 9-Audio.wav
2024-03-01 16:55:40.565 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%209-Audio.wav
2024-03-01 16:55:40.565 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test 9-Audio.wav
2024-03-01 16:55:40.565 [debug]: Local Library Sync: Synching new/modified file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test A-Reverb.wav
2024-03-01 16:55:46.743 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%20A-Reverb.wav
2024-03-01 16:55:46.744 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test A-Reverb.wav
2024-03-01 16:55:46.744 [debug]: Local Library Sync: Synching new/modified file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test B-Delay.wav
2024-03-01 16:55:48.798 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:49.144 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:50.026 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:50.380 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:50.746 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:51.108 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:51.453 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:51.797 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:52.181 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:52.534 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:52.913 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:53.265 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:53.609 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:53.959 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:54.306 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:55:57.223 [error]: AudioFileLoader: Error -2147417825 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test%20B-Delay.wav
2024-03-01 16:55:57.224 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test B-Delay.wav
2024-03-01 16:55:57.225 [debug]: Local Library Sync: Synching new/modified file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test.wav
2024-03-01 16:56:39.474 [error]: AudioFileLoader: Error -1072875836 opening media foundation file: file://C%3A%5CUsers%5CAdmin%5CMusic%5CMusic%5CKyle%20Files%5C31%20Band%20Pink%20Noise%5C__MACOSX%5C31%20band%20test%5C__31%20band%20test.wav
2024-03-01 16:56:39.475 [warning]: Local Library Sync: Not synching unreadable file C:\Users\Admin\Music\Music\Kyle Files\31 Band Pink Noise__MACOSX\31 band test__31 band test.wav
2024-03-01 16:57:50.739 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:57:51.091 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:57:51.453 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:57:51.803 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:57:52.155 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:57:52.503 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:57:52.860 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:57:53.213 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:57:53.567 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:57:53.924 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:57:54.280 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:57:54.629 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:57:54.983 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:57:55.335 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:57:55.688 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 16:59:35.135 [info]: ============= Started Logging, Audirvana Studio 2.7.0 (20700) =============
2024-03-01 16:59:40.961 [info]: RemoteServer: Server started and advertised on port 49682
2024-03-01 16:59:41.472 [info]: UPnP stack initialized using default interface
2024-03-01 16:59:41.674 [info]: UPnP web server started on 172.16.0.50:49152
2024-03-01 16:59:42.456 [error]: VST new user location scan error C:\Users\Admin\AppData\Local\Programs\Common\VST3: unable to enumerate files
2024-03-01 17:12:34.092 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:12:34.477 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:12:34.832 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:12:35.182 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:12:35.542 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:12:35.886 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:12:36.439 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:12:36.786 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:12:37.141 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:12:37.496 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:12:37.854 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:12:38.245 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:12:38.608 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:12:38.958 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:12:39.305 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:17.976 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:27.236 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:27.587 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:27.953 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:28.333 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:28.680 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:29.020 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:29.365 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:29.713 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:30.070 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:30.433 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:30.779 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:31.130 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:31.487 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:31.885 [error]: Qobuz getTrackFileReqUrl error: 400
2024-03-01 17:15:32.255 [error]: Qobuz getTrackFileReqUrl error: 400
I figured it out. The date was wrong…
Glad that you got it fixed. I just did a search on Qobuz 400 Error and the Date issue was described in relation to a Hiby Device.
Enjoy the music… :+1:
