There is a free plug-in named Quark which can decode Quadraphonic QS signals encoded in stereo files. There are many QS encoded recordings available from streaming services, such as Qobuz. If we have a 4 speaker system we can enjoy these in Quadraphonic sound by running them through this plug-in.
Examples include many artists I love, such as Alice Coltrane, John Coltrane, Pharoah Sanders and Santana, just to name a few. They tend to be mainly from the early 70’s when there was a commercial push for Quad. A list of known QS encoded CDs, can be found here
Unfortunately when it comes to judging if you are, indeed, getting true Quadraphonic from these titles, via the Quark plug-in, you will have to judge by ear, because as Richard Brice of pSpatial explained to me, “the milk is mixed in with the coffee”. So you have to listen for discrete elements from your rear left and right speakers, to be sure you’re getting bone fide Quad. However, you will not do any harm if you end up running a plain stereo file through this plug-in and it may even sound a little better.
The reason I’m posting about this here is that it can’t work in Audirvana. That may not be a fault of Audirvana though. The reason is if you start off with a Stereo source file and feed it into a plug-in, which produces 4 channels, how do you know where the rear left and right channels should be routed?
So I’m sending Audirvana’s output to Blackhole and using a pre-compiled Juice plug-in host app to run the 4 channel outputs from Blackhole into Quark and then routing them to the appropriate corresponding channels of my final output device.
In a 5.1 or higher set-up such as with my Exasound multi-channel DAC, the left and right rear channels are 5 and 6. This can’t be assumed though.
If you try to use Quark in Audirvana right now, it can’t be configured. Clicking on the “Configure” button does not cause its settings window to appear.
So I’m posting this here as a general question for @Antoine and others. Could such a plug-in that can produces more channels of audio data than are fed into it, be made to work in Audirvana? Perhaps if the plug-in developer included a way of indicating which channels of the output device each signal should be mapped too?
