Quboz not showing Genre selection
In the regular Quboz app there is a Genre Selection choice so you can narrow down your search. I can’t find that option in the Quboz section of Audirvana Studio
Under Qobuz/Discovery click the filter funnel on the top right hand side. The Genre Selection Toll will appear. Select all 14 or whatever you want.
Thanks I’ll check that out
Thank you again. That worked.
