Any suggestions as to the ‘best’ setting for “Native DSD Capability” with a DAC which takes up to DSD256, but appears not to recognise A+ when set to “Automatic Detection”.
DoP over PCM 1.0 and 1.1 work but looking here (http://dsd-guide.com/dop-open-standard#.Wqje-2acZR4 ) I cannot see what really changed 1.0 -> 1.1 unless it was just absorbing 1.0.2 and 1.0.3 updates.
i think 1.1 introduce DSD256 or/and 512, i can’t remember. mine is at 1.1 even if my DAC stop at DSD128
Not so sure about that - my DAC shows DSD 11.2MHz with 1.0 or 1.1
If it works with 1.1, leave it there, it is the most recent
Will do then. Perhaps you could take a look at the dropout issue with DSD256 as well… thanks
Aurius
October 26, 2022, 11:31am
6
For me over PCM1.1 sounds warmer and fuller, bigger and wider sound stage. Over PCM1.0 thinner and more airy.
