Since the last update 3.5.5 the login fail with Quobuz. No connection possible anymore!
Have anybody experience that problem. My connection with Quobuz works perfectly with Amara. I downloaded the trial version to show that I still have the right connection.
Hello @spaini ,
The issue came from Qobuz, probably due to a change in their API. You should now be able to streming music from Qobuz in Audirvana
No, Still getting login error. It recognizes my username but won’t let me connect. Uninstalled/reinstalled. Restarted everything. Still no luck.
