I listen to Radio Paradise as background music but it frequently cuts out when using Audirvāna. I’m assuming it’s a buffering issue but my internet is pretty stable and when using Roon I don’t have the same problem. Is there some way to increase the buffering?
Hello @Ben54,
I took this Debug Info just after Radio Paradise dropped out.
Audirvana Studio 2.1.0 (20100)
macOS 13.0.1 with 8GB physical RAM
Connected account of : Ben Searle
Per track: OFF
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Stop band attenuation 152.449dB
Max allowed volume: 95.7742
AUTO: /Volumes/Music/Music
Library database path: /Users/ben/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 61132
Active method: UPnP
Preferred device: PS AUDIO BRIDGEIIINPUTROY Model UID:PS Audio DirectStream DAC UID:uuid:3A5BCA42-1F56-124A-BFEF-985E1B7E50DA
Selected device:BridgeIIInputROY
Manufacturer: PS Audio
Model name: DirectStream DAC
Model UID: PS Audio DirectStream DAC
UID: uuid:3A5BCA42-1F56-124A-BFEF-985E1B7E50DA
UPnP device at http://192.168.0.108:38400/description.xml
ID 0x0
Volume control: Yes
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
http-get:*:audio/mpeg:dlna.org_pn=mp3
http-get:*:audio/mp4:dlna.org_pn=mp4
http-get:*:audio/vnd.dlna.adts:dlna.org_pn=aac_adts
http-get:*:audio/x-ms-wma:dlna.org_pn=wmabase
http-get:*:audio/x-ms-wma:dlna.org_pn=wmafull
http-get:*:audio/x-ms-wma:dlna.org_pn=wmapro
http-get:*:audio/x-ms-wma:dlna.org_pn=wmalsl
http-get:*:audio/x-sony-oma:dlna.org_pn=atrac3plus
http-get::audio/aiff:
http-get::audio/wav:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
http-get::audio/ac3:
http-get::audio/x-dsf:
http-get::audio/mp4:
http-get::audio/x-wav:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: dB
12 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
<?xml version="1.0"?>1
0
BridgeIIInputROY
PS Audio
This model is a connected audio module which supports the UPnP/DLNA standard specification.
DirectStream DAC
CDMCM-210-001
<dlna:X_DLNADOC xmlns:dlna=“urn:schemas-dlna-org:device-1-0”>DMR-1.50</dlna:X_DLNADOC>
image/png
48
48
24
/images/small.png
image/png
120
120
24
/images/large.png
image/jpeg
48
48
24
/images/small.jpg
image/jpeg
120
120
24
/images/large.jpg
/service/RenderingControl1.xml
/service/RenderingControl_control
/service/RenderingControl_event
/service/ConnectionManager1.xml
/service/ConnectionManager_control
/service/ConnectionManager_event
/service/AVTransport1.xml
/service/AVTransport_control
/service/AVTransport_event
0
BridgeIIInputROY
PS Audio
DirectStream DAC
CDMCM-210-001
image/png
48
48
24
/images/small.png
image/png
120
120
24
/images/large.png
image/jpeg
48
48
24
/images/small.jpg
image/jpeg
120
120
24
/images/large.jpg
UPnP devices found : 1
Device #0: ID 0x0 : BridgeIIInputROY
Max. memory for audio buffers: 3492MB
Local Audio Engine: CoreAudio
Device #0: ID 0x53 Built-in Output
Model UID: AppleHDA:14
UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x30 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Chromecast devices found : 1
Device #0: TV
Model name: BRAVIA 4K UR2
Hello @Ben54,
Can you please update to the latest version and then remove the audio units you have set and try to play Radio Paradise again?
I was using the latest version but I have deleted the app and downloaded and installed it again. You suggest “removing the Audio Units and trying Radio Paradise again.” I’m not sure what you mean by the audio units……sorry for my lack of knowledge. If you could let me know what the Audio Units are I will try again.
Hi Antoine, I have reloaded the latest version of Audirvana Studio (I was using the latest version) and I have deactivated the Audio Units. I played Radio Paradise fr about 15 minutes before it dropped out again.
Below is the debugging information…
Audirvana Studio 2.2.0 (20200)
Listening on 127.0.0.1 on port 63574
Active method: UPnP
Preferred device: [UPnP] BridgeIIInputROY Model UID:PS Audio DirectStream DAC UID:uuid:3A5BCA42-1F56-124A-BFEF-985E1B7E50DA
ID 0x0
Volume control: Yes
http-get::audio/mpeg:dlna.org_pn=mp3
http-get::audio/mp4:dlna.org_pn=mp4
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts
http-get::audio/x-ms-wma:dlna.org_pn=wmabase
http-get::audio/x-ms-wma:dlna.org_pn=wmafull
http-get::audio/x-ms-wma:dlna.org_pn=wmapro
http-get::audio/x-ms-wma:dlna.org_pn=wmalsl
http-get::audio/x-sony-oma:dlna.org_pn=atrac3plus
DLNA 1.5: Yes
Volume Control: dB
12 virtual formats:
0 physical formats
NrTracks: 0
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Play
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 BridgeIIInputROY PS Audio http://www.conversdigital.com This model is a connected audio module which supports the UPnP/DLNA standard specification. DirectStream DAC CDMCM-210-001 uuid:3A5BCA42-1F56-124A-BFEF-985E1B7E50DA http://www.conversdigital.com DMR-1.50 image/png 48 48 24 /images/small.png image/png 120 120 24 /images/large.png image/jpeg 48 48 24 /images/small.jpg image/jpeg 120 120 24 /images/large.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /service/RenderingControl1.xml /service/RenderingControl_control /service/RenderingControl_event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /service/ConnectionManager1.xml /service/ConnectionManager_control /service/ConnectionManager_event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /service/AVTransport1.xml /service/AVTransport_control /service/AVTransport_event http://192.168.0.108:38400Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 BridgeIIInputROY PS Audio http://www.conversdigital.com This model is a connected audio module which supports the UPnP/DLNA standard specification. DirectStream DAC CDMCM-210-001 uuid:3A5BCA42-1F56-124A-BFEF-985E1B7E50DA http://www.conversdigital.com DMR-1.50 image/png 48 48 24 /images/small.png image/png 120 120 24 /images/large.png image/jpeg 48 48 24 /images/small.jpg image/jpeg 120 120 24 /images/large.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /service/RenderingControl1.xml /service/RenderingControl_control /service/RenderingControl_event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /service/ConnectionManager1.xml /service/ConnectionManager_control /service/ConnectionManager_event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /service/AVTransport1.xml /service/AVTransport_control /service/AVTransport_event http://192.168.0.108:38400UPnP devices found : 1
Device #0: TV
Can you go in your audio output settings and enable the option to not send RAW PCM stream?
Hi Antoine, many thanks for your help and suggestions. I have tried the RAW PCM setting as you have suggested and this seems to be working so far. I’ve had Radio Paradise running for a few hours now with no stoppages so far. By the way, I’m not sure if it’s my imagination but the sound quality seems to have improved slightly.
Anyway, thanks again and wishing you a merry Christmas
I’m back again….Radio Paradise is still dropping out after 20 or 30 minutes or so.
I also have another issue. I might have changed some settings (but can’t find where) that is resulting in only one track of an album playing. The play list shows the full album but the next track does not start. I have tried it with random play but while the first song is selected randomly, it stops after the track has finished.
Any help greatly appreciated.
Hi @Ben54,
For testing purpose, have you tried to reproduce this behavior with Chromecast over your TV or by playing the radio through the built-in output?
I haven’t tried that but will. I tried using the app directly from the Mac after I deleted the Mac and iPad versions and re installing the software. It does seem to be behaving correctly on albums. I will try radio tomorrow and also using the Mac speaker.
I have been playing Radio Paradise from the Audirvāna app on my Mac through the Mac speakers for over 6 hours and no issues with dropping out. It appears that connecting to my PS Audio DAC via UPnP is where the problem might be occurring.
Any ideas?
Ok, we are then narrowing the problem. Can you try enable the option in the audio output settings “Universal gapless playback” and then try again to play Radio Paradise?
I will try that and let you know how it goes….thanks
I am now using my iPad to control the music and Radio Paradise has dropped out 4 times, lasting about 3-4 minutes of playing.
I had previously set universal hapless playback as suggested
The Radio Paradise is still cutting out after a short time. Also, when I play an album the first track plays but stops after that. I need to manually start each track.
I love the sound produced by Audirvāna but getting it behave and play correctly is a little frustrating. Any thoughts?
