Radio display
When I select a radio station from favourites the display on my device shows the format/bitrate etc rather than the piece playing. Everything else displays correctly.
Is there a setting I’m missing or is this a bug?
Thanks.
Alan
Hi @the_bat , are you using a UNPP device? If so, what is its name and its brand?
Hi Antoine.
I’m using an Aurender N20 as my UPNP device.
Do you think this might be device specific, rather than an Audirvana issue?
Alan
I think it’s probably because we don’t update the information sent to the device when it comes to UPNP with radio, I need to double-check on my end.
OK - so hopefully a fairly simple fix to add to the list.
