Try to play radio, get msg about loading and resolution, starts âplayingâ and⌠no sound. Sometimes get msg on problems in firewall and no problems in firewall.
Tidal works.
Audirvana Studio 2.8.1 (20801)
Windows 11 (22621) with 16GB physical RAM
Available network interfaces:
Ethernet 2 ({99866d78-44b1-4c47-81a3-3d9e53ba3a4a}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
r8brain to DSD256 with filter type B 7th order
Phase minimum phase
AUTO: \N-2A33\Internal\import_CD
Library database path: C:\Users\trots\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 93
Listening on 2a0d:6fc2:4862:9e00:25da:ff2e:451:565f on port 51016
TIDAL: Connected as HiFi Plus
Font size: regular
My Music
Radios
Podcasts
Streaming
Number of paired remotes: 0
Screen saver disabled: yes
Active method: UPnP
Preferred device: [UPnP] N-2A33 E70:MediaRenderer Model UID:MELCO Syncrets Inc. MELCO Music Player UID:uuid:12bd4d8d937974014cbf40a1671ede2f
Currently playing to UPnP device at 32 bits 11289.6kHz
Selected device:N-2A33 E70:MediaRenderer
Manufacturer: MELCO Syncrets Inc.
Model name: MELCO Music Player
Model UID: MELCO Syncrets Inc. MELCO Music Player
UID: uuid:12bd4d8d937974014cbf40a1671ede2f
UPnP device at http://192.168.1.210:49494/12bd4d8d937974014cbf40a1671ede2f.xml
12 available sample rates up to 22579200Hz
5644800
11289600
22579200
Volume control: Yes
Max volume alert: Disabled
Raw DSD (msb)
UPnP set capabilities
Maximum PCM frequency set: 384000Hz
Maximum PCM bitdepth set: 32
Maximum DSD rate set: DSD512
Avoid RAW PCM streams: No
Unwanted playback stop workaround: Yes
http-get::::::
http-get::http-get::::*
http-get::audio/x-aac:
http-get::audio/aac:
http-get::audio/ogg:
http-get::audio/L16;rate=44100;channels=2:
http-get::audio/x-scpls:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/x-dff:
http-get::audio/x-dsf:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/alac:
http-get::audio/x-alac:
http-get::audio/mp4:
http-get::audio/m4a:
http-get::audio/x-m4a:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB (-60dB to 0dB)
2 ch DSD 8bit little endian in 8bit chunk 22579.2kHz finite length
NrTracks: 1
MediaDuration:
CurrentURI: http://192.168.1.167:49152/audirvana/audio_r_3.dff
CurrentURIMetadata:
dc:titlemp3, 44100 Hz, stereo, 128 kb/s</dc:title>
upnp:albumArtURIhttp://static.airable.io/49/47/351454.png</upnp:albumArtURI>
upnp:albumר×××ץ</upnp:album>
nextURI:
nextURIMetadata:
PlayMedium: NOT_IMPLEMENTED
Current transport actions:
PAUSE,STOP,SEEK
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 N-2A33 E70:MediaRenderer MELCO Syncrets Inc. http://www.melco-audio.com/ MELCO Music Player 3.0.0 MELCO Music Player 2023-12-07_8e0476a78 http://www.melco-audio.com/ uuid:12bd4d8d937974014cbf40a1671ede2f image/png 48 48 24 /upnp/grender-48x48.png image/png 120 120 24 /upnp/grender-120x120.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/rendertransportSCPD.xml /upnp/control/rendertransport1 /upnp/event/rendertransport1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/renderconnmgrSCPD.xml /upnp/control/renderconnmgr1 /upnp/event/renderconnmgr1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/rendercontrolSCPD.xml /upnp/control/rendercontrol1 /upnp/event/rendercontrol1 http://192.168.1.210:49494/Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 N-2A33 E70:MediaRenderer MELCO Syncrets Inc. http://www.melco-audio.com/ MELCO Music Player 3.0.0 MELCO Music Player 2023-12-07_8e0476a78 http://www.melco-audio.com/ uuid:12bd4d8d937974014cbf40a1671ede2f image/png 48 48 24 /upnp/grender-48x48.png image/png 120 120 24 /upnp/grender-120x120.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/rendertransportSCPD.xml /upnp/control/rendertransport1 /upnp/event/rendertransport1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/renderconnmgrSCPD.xml /upnp/control/renderconnmgr1 /upnp/event/renderconnmgr1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/rendercontrolSCPD.xml /upnp/control/rendercontrol1 /upnp/event/rendercontrol1 http://192.168.1.210:49494/UPnP devices found : 1
Device #0: N-2A33 E70:MediaRenderer
Location: http://192.168.1.210:49494/12bd4d8d937974014cbf40a1671ede2f.xml
Max. memory for audio buffers: 1410MB
Local Audio Engine: WASAPI
Device #0: Speakers (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0256&SUBSYS_10431893&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{403fe41b-5b58-4bf5-9b60-f4535f563d8b}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio
Chromecast devices found : 1
Device #0: Family room TV
Model name: BRAVIA 4K VH2
