Playback is normal from my NAS and Tidal, but when I start a radio station, it starts playing, plays for around a second then stops. It doesnât seem to matter whether the station is being streamed mp3 128 kb/s or FLAC 1411 kb/s.
Hi @pawhit,
Can you send us a copy of the "Debug Infoâ when you have this issue? You can get it in Audirvana Settings>My account.
Note: By clicking on the Debug Info button, Audirvana automatically copies all its content. All you have to do is paste it in response to this message.
Thanks, here it is:
Audirvana Studio 2.8.0 (20800)
macOS 12.7.3 with 24GB physical RAM
Connected account of : Paul Whitaker
Sync list: 2 folders
AUTO: /Volumes/music/DSD64
AUTO: /Volumes/music/Lossless
Library database path: /Users/paulwhitaker/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Deep Synch: yes
Scanning 40/253: /Volumes/music/DSD64/1983 - Spandau Ballet - True [SACD DSF][2003]/08 - Spandau Ballet - True.dsf
Folders queued for synchronization:
Deep Synch: yes
Tracks with no MBID: 9084
Listening on 127.0.0.1 on port 49273
TIDAL: Connected as HiFi Plus
Active method: UPnP
Preferred device: [UPnP] NACN272-D7FE Model UID:Naim Audio Ltd. NAC-N 272 UID:uuid:5F9EC1B3-ED59-79BB-4530-0011F6AFD7FE
Selected device:NACN272-D7FE
Manufacturer: Naim Audio Ltd.
Model name: NAC-N 272
Model UID: Naim Audio Ltd. NAC-N 272
UID: uuid:5F9EC1B3-ED59-79BB-4530-0011F6AFD7FE
UPnP device at http://192.168.0.234:8080/description.xml
ID 0x0
8 available sample rates up to 5644800Hz
5644800
Volume control: Yes
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD128
Avoid RAW PCM streams: No
http-get::audio/L16;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/wav:*
http-get::audio/x-mpegurl:
http-get::application/ogg:
http-get::audio/mp4:
http-get::audio/x-flac:
http-wavetunes::audio/x-ms-wma:
http-get::audio/x-aiff:
http-get::audio/x-m4a:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::application/x-mpegurl:
http-get::audio/x_pm_flac:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
22 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 88.2kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 88.2kHz
0 physical formats
NrTracks: 1
MediaDuration: NOT_IMPLEMENTED
CurrentURI: http://192.168.0.164:49152/audirvana/audio_r_1.pcm
CurrentURIMetadata: dc:titleflac, 44100 Hz, stereo, 1411 kb/s</dc:title>upnp:artistflac, 44100 Hz, stereo, 1411 kb/s</upnp:artist>upnp:albumRadio Paradise Main Mix</upnp:album>upnp:albumArtURIhttp://static.airable.io/85/90/915765.png</upnp:albumArtURI>http://192.168.0.164:49152/audirvana/audio_r_1.pcm
nextURI: http://static.airable.io/85/90/915765.png
nextURIMetadata: dc:titleaac, 44100 Hz, stereo, 320 kb/s</dc:title>upnp:artistaac, 44100 Hz, stereo, 320 kb/s</upnp:artist>upnp:albumRadio Paradise Main Mix</upnp:album>upnp:albumArtURIhttp://static.airable.io/85/90/915765.png</upnp:albumArtURI>http://static.airable.io/85/90/915765.png
PlayMedium: NETWORK
Current transport actions:
Play,Next,Previous
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 NACN272-D7FE Naim Audio Ltd. http://www.naimaudio.com Naim NAC-N 272 Streaming Pre-ampp NAC-N 272 20-002-0005 https://www.naimaudio.com/product/nac-n-272 0011F6AFD7FE uuid:5F9EC1B3-ED59-79BB-4530-0011F6AFD7FE 123810928305556upc urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-dm-holdings-com:service:X_HtmlPageHandler:1 urn:schemas-dm-holdings-com:serviceId:X_HtmlPage /HtmlPageHandler/desc.xml /HtmlPageHandler/ctrl /HtmlPageHandler/evt http://192.168.0.234:80/index.asp urn:rhapsody-real-com:device-id-1-0:rdk_dev_2:0011F6AFD7FECurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 NACN272-D7FE Naim Audio Ltd. http://www.naimaudio.com Naim NAC-N 272 Streaming Pre-ampp NAC-N 272 20-002-0005 https://www.naimaudio.com/product/nac-n-272 0011F6AFD7FE uuid:5F9EC1B3-ED59-79BB-4530-0011F6AFD7FE 123810928305556upc urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-dm-holdings-com:service:X_HtmlPageHandler:1 urn:schemas-dm-holdings-com:serviceId:X_HtmlPage /HtmlPageHandler/desc.xml /HtmlPageHandler/ctrl /HtmlPageHandler/evt http://192.168.0.234:80/index.asp urn:rhapsody-real-com:device-id-1-0:rdk_dev_2:0011F6AFD7FEUPnP devices found : 3
Device #0: ID 0x0 : Marantz NR1711
UID: uuid:5c7ae672-caa4-1249-0080-0006783bda42
Location: http://192.168.0.193:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Marantz
Model name: Marantz NR1711
Device #1: ID 0x0 : NACN272-D7FE
Device #2: ID 0x0 : Qute-4111
UID: uuid:5F9EC1B3-ED59-79BB-4530-0011F6A64111
Model name: UnitiQute
Max. memory for audio buffers: 21504MB
Local Audio Engine: CoreAudio
Device #0: ID 0x47 Built-in Output
Model UID: AppleHDA:130
UID: AppleHDAEngineOutput:1F,3,0,1,2:0
Device #1: ID 0x37 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
That seemed to fix it. Will these setting have any detrimental impact on playback from Tidal or my NAS which I wanât having issues with?
No they wonât ![]()
