Hello,
the random feature does not work at all!!!
It’s been month I’m trying to listen to play list of 1000 songs randomly but no. Not working.
Can you please fix this annoying issue.
Audirvana Mac Version 3.5.16 (3546)
macOS 10.14.5 with 8192MB RAM
Licence enregistrée pour Christophe Marcourt
SW volume control: ON
AUTO: /Volumes/music/
Library database path: /Users/hifiplayer/databases/version1/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 5632MB
OPPO Sonica DAC USB AUDIO 2.0 DAC
Model UID:OPPO Sonica DAC USB AUDIO 2.0 DAC:22D9:0436
UID:AppleUSBAudioEngine:OPPO:OPPO Sonica DAC USB AUDIO 2.0 DAC:14700000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
ID 0x27 OPPO Sonica DAC USB AUDIO 2.0 DAC Manufacturer:OPPO
Model UID:OPPO Sonica DAC USB AUDIO 2.0 DAC:22D9:0436 UID:AppleUSBAudioEngine:OPPO:OPPO Sonica DAC USB AUDIO 2.0 DAC:14700000:1
Stream ID 0x28 2 channels starting at 1
20 virtual formats:
20 physical formats
Device #0: ID 0x2a Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x27 OPPO Sonica DAC USB AUDIO 2.0 DAC Manufacturer: OPPO Model UID: OPPO Sonica DAC USB AUDIO 2.0 DAC:22D9:0436 UID: AppleUSBAudioEngine:OPPO:OPPO Sonica DAC USB AUDIO 2.0 DAC:14700000:1
UPnP devices found : 1
Device #0: ID 0x0 Uniti-E8D7 UID: uuid:5F9EC1B3-ED59-79BB-4530-001A2B88E8D7 Location: http://172.22.22.202:8080/description.xml
