Antoine, here it is:
Audirvana Origin 2.5.11 (20511)
macOS 10.15.7 with 16GB physical RAM
Connected account of : laurent Tarrade
Bandwidth at 0dB = 99.5%
Phase = 66%
Replay Gain: by track
SW volume control: ON
AUTO: /Volumes/music/
Library database path: /Users/laurent/Documents/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 53907
Max. memory for audio buffers: 8562MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
McIntosh McIntosh-HD HS USB Audio
Model UID:McIntosh-HD HS USB Audio:2AFD:0002
UID:AppleUSBAudioEngine:McIntosh:D150:14200000:2
Active Sample Rate: 48kHz
Selected device:Sortie intégrée
Model name: Apple Inc. Sortie intégrée
Model UID: AppleHDA:88
ID 0x33
DSD via PCM 1.0
Stream ID 0x34 2 channels starting at 1
4 virtual formats:
16 physical formats
Device #0: ID 0x33 Sortie intégrée
UPnP devices found : 1
Device #0: ID 0x0 : XBOX3T
UID: uuid:6281cea2-293f-4c29-a840-b9e6e3b191e2
Location: http://10.0.0.10:2869/upnphost/udhisapi.dll?content=uuid:6281cea2-293f-4c29-a840-b9e6e3b191e2
Manufacturer: Microsoft Corporation
Model name: Xbox One
Chromecast devices found : 1
Device #0: SONY KD-55A8
Model name: BRAVIA 4K UR3
