Hi! I’m using Audirvana Studio in MacOS Monterey (v12.0 on Macbook Pro M1). I’m trying to use realtime plugins but their windows are not properly resized or resizeable. Apple’s own AU plugins show up though. I also have intel based Macbook Pro and all works fine there… Any help?
Hello @cany89,
Sure, here:
Audirvana Studio 1.10.2 (11002)
macOS Version 12.0 (Build 21A344) with 16GB physical RAM
Connected account of : Can Yelok
Effects plugins ACTIVE in realtime mode with legacy macOS API
AU plugin #0: Music Effect - FabFilter FF Pro-Q 3 ()
AU plugin #1: Effect - Goodhertz Ghz CanOpener Studio 3 ()
AU plugin #2: None
AU plugin #3: None
AUTO: /Users/canyelok/Dropbox/Music
Library database path: /Users/canyelok/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 55686
RME ADI-2 DAC (59930755)
Model UID:ADI-2 DAC (59930755):2A39:3FD3
UID:AppleUSBAudioEngine:RME:ADI-2 DAC (59930755):5F190C15F8E0AC8:1,2
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 192kHz
Active Sample Rate: 192kHz
Hog Mode is on
ID 0x50 ADI-2 DAC (59930755)
Manufacturer: RME
Model Name: RME ADI-2 DAC (59930755)
Model UID: ADI-2 DAC (59930755):2A39:3FD3
UID: AppleUSBAudioEngine:RME:ADI-2 DAC (59930755):5F190C15F8E0AC8:1,2
Stream ID 0x51 2 channels starting at 1
20 virtual formats:
20 physical formats
Local devices found : 3
Device #0: ID 0x41 LG HDR 4K Manufacturer: GSM Model UID: 1E6D0677-0000-0000-031D-0103803C2278 UID: 1E6D0677-0000-0000-031D-0103803C2278 Model Name: GSM LG HDR 4K
Device #1: ID 0x50 ADI-2 DAC (59930755) Manufacturer: RME Model UID: ADI-2 DAC (59930755):2A39:3FD3 UID: AppleUSBAudioEngine:RME:ADI-2 DAC (59930755):5F190C15F8E0AC8:1,2 Model Name: RME ADI-2 DAC (59930755)
Device #2: ID 0x35 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Pro Speakers
Hello,
have you tried to disable and enable those plugin again to see if you still have this issue?
The fabfilter one at least had an update not long time ago. Maybe because of Monterey system… you should check. Mine works good, and Monterey 12.2 was release yesterday…
@Antoine I checked the experimental checkbox and plugins opened as usual on realtime.
@RunHomeSlow it wasn’t about updating Monterey or Fab as I can use them without any update on my DAW on m1 12.0.
Problem solved for now.
Thanks for the follow up
