With the help of Apple Care I may have to perform a Wipe of my Mac mini. Can I get another copy of Audirvana? How do I recovery Audirvana?
Deactivate Audirvana and just re-install after you restore your Mac.
Thank you. Now how do I delete my entire Audirvana library so I can start over?
Randy
Go to /Users/[username]/Library/Application Support/Audirvana. The databese is AudirvanaPlusDatabaseV2.sqlite file. Delete it and restart Audirvana to start over.
Deactivating before wiping out your mac is good…
Well, if you have to wipe your Mac… Wipe it
Then on fresh System, you just have to download Audirvana trial again on website…
When asked, enter your serial number… all will be fresh new after that…
Thanks and I appreciate your time.
