I recently purchased a subscription, (April 9th) less than 45 days later, that product is end of lifed.
How do I get my money back?
Thank you
Thank you
Not so much as a reply despite being obviously active elsewhere.
At no point in the development cycle of the new product was it thought to stop selling lifetime membership for a product you had already set to bitrot.
The new product crashed when I loaded it, and the few files it did touch it changed the md5sums on because, YOU know my needs better than I.
I now understand your integrity sells for $96.
I would have held out for more personally.
You may want to convert it into subscription at a discount, or stick with it if you don’t like subscriptions. It’s going to work for years to come.
Still if you don’t like any if the options above, write to support@audirvana.com.
Hello @MamaTried,
First of all Audirvana is not a subscription, it’s a license you have purchased and you will still be able to use it without a limit of time. If your worry was about not being able to access to 3.5 anymore, this will not be the case.
Hey thanks, a week after I asked I get licensing mansplained to me.
Feel free to make sure I removed my authorization properly. Betting I did.
Let the bit rot begin.
Thank you for your time.
And again, I appreciate your input.
Have a great day.
Damien
How long do you anticipate supporting 3.5?
To be fair, he also paid the $96 with expectation of some future maintenance/bug fix updates.
