Following 2023-07-31T22:00:00Z’s update of Origin, here is the change log of the 2.4 version:
MacOS:
Local Library Synchronization: Ensures all folders and audio files are synchronized even in rare cases where recent macOS randomly could miss files located on some specific NAS models
Playlist editor: Now checks for existing tracks when adding new ones to a playlist. Asks if the user wants to add them all, or only the tracks not already in the playlist
Remote: Now shows the ‘Plāys with Audirvāna’ device popup when selecting such a certified device from the remote app
Other minor fixes
Windows:
Other minor fixes
Change log of the 2.3.4 version for reference:
MacOS:
- Native DSD playback: fix issue playing DSD file to native DSD player
Windows:
Change log of the 2.3.3 version for reference:
MacOS:
Offline mode: Avoid occasional error an hour after having lost the Internet connection
DSD to PCM algorithm: Extension of the frequency upper limit, for DACs not compatible with native DSD. They can now play DSD1024 up to their max PCM frequency (e.g. 705.6kHz)
Other minor fixes
Windows:
VST3 plugins: Now handling multichannel plugins
Other minor fixes
