Following today update of Studio, here is the changelog of this 1.2 version:
MacOs:
NEW: Saving the track Musicbrainz ID in audio file metadata is now an opt-in option in settings, set to off by default
Fix HRA streaming playlists and genres browse
Fix add/remove/reorder tracks in TIDAL playlist
Fix playlists navigator expand/collapse folder
Windows 10:
Fix creation of Qobuz playlist
Other minor fixes
For Windows 10 users only , if you don’t have the automatic update you need to go to Download - Audirvana to get the update.
