IMPORTANT
For all Windows 10 users of Studio, please take a look at the change log to properly get the update and not having to do the analysis of your track.
Following today’s update of Studio, here is the change log of this 1.4.5 version:
MacOs:
Fix display issues on High Sierra
Show number of active filters in toolbar button
Fix streaming playlist album play
Windows 10:
We made a change due to Microsoft security policy for Audirvana Studio Windows 10 version. This then means you will need to do a couple of things to get the update.
IMPORTANT: Before uninstalling Studio, you need to copy your AudirvanaDatabase.sqlite file that you can find at this location:
To show AppData folder:
https://support.microsoft.com/en-us/windows/view-hidden-files-and-folders-in-windows-10-97fbc472-c603-9d90-91d0-1166d1d9f4b5
Copy and save it in a different folder BEFORE uninstalling Studio (It’s mandatory to not lose the analysis of your tracks)
You then need to uninstall Studio from your computer (right-click on the icon in start menu and select Uninstall)
And then install the latest version using the link Download - Audirvana
After doing this, open Studio one time and close it. Then go to the same location as before:
Replace the AudirvanaDatabase.sqlite file.
You can now reopen Audirvana Studio and the analysis of your tracks should not be done again.
Change log of 1.4.5 for Windows 10:
Improve audio files analysis progress information
Allow pause in radio playback
Other minor fixes
