Following today’s update of Studio, here is the change log of this 1.6.4 version:
MacOS:
- Huge libraries: improve navigation performance
- Mixed playlists (including tracks from local library, streaming, podcasts, …): Fix album display
- UPnP: workaround for devices with buggy gapless implementation
- MQA: Fix 16bit MQA read to a MQA renderer device
- Radios: workaround for playing radios from Shoutcast servers not delivering correct MIME type
- Playlist contents view: shrink header when scrolling
- Streaming playlist: fix long manual playlist sort
- Other minor fixes
Windows 10:
- Metadata: fix read/write in huge files (more than 2GB)
- Other minor fixes
