Following 2025-10-08T22:00:00Z update of Studio (2025-10-21T22:00:00Z for macOS), here is the changelog of the 2.11.5 version:
MacOS:
- macOS 26 Tahoe: Volume change fix for USB devices for which macOS does not provide a correct dB volume value
- macOS 26 Tahoe: Music app can’t be fully controlled by another application like Audirvāna, Music Integrated mode no longer works. A Pop-up now appears when you try to activate this option.
Linux:
- Local library sync: removing a folder that is no longer accessible is now possible
- Internet radios: update sample rate of a radio stream displayed in a playlist when it was unknown (e.g. by entering directly the URL of the radio)
- Other minor fixes
