Following 2024-05-28T22:00:00Z's update of Studio, here is the changelog of the 2.8.2 version:
MacOS:
Offline mode: Improve the failsafe mechanism in case of critical Microsoft Azure failure, to allow offline playback of local audio files
Audio settings: “Use as Stereo Only” toggle now enables to select the stereo stream instead of the multichannel one
UPnP: improve “Fix for devices with unwanted playback stops” efficiency for helping playback with some buggy devices
Plays with Audirvāna: after three selections of the same device, the certified device popup will no longer automatically be displayed
Remote settings: improve synchronized folder selection
Audio file metadata: replayGain ID3 tags have now a space character between the number and “dB” for improved compatibility
Local Artist: play all command now plays only the artist albums
Other minor fixes
Windows:
Other minor fixes
