Release note Audirvāna Studio 2.9.4
Following 2024-11-13T23:00:00Z's update of Origin, here is the changelog of the 2.9.4 version:
MacOS:
  • Audio settings: When real-time processing is active, the processing steps order is now modified to reflect the actual one, i.e., the processing is made after the volume leveling.
  • Tracks list: fix sort reordered column issue
  • Memory usage optimization decreases the total RAM footprint. There is no official change in system requirements.
  • Remote: button added to rescan the network for UPnP outputs in the audio settings, DAC input section
  • Other minor fixes
Windows:
  • Tracks list: fix rating display issue and allow to change track rating by clicking on it
  • Other minor fixes
Linux:
  • Other minor fixes
