Release note Audirvāna Studio 3.1
Following 2026-05-11T22:00:00Z update of Studio, here is the changelog of the 3.1 version (all other 3.0 updates are also included for reference):
MacOS:
  • NEW Lyrics display feature: when a playing song has lyrics, there is a button in the player to open a panel showing them
  • Other minor fixes
Windows:
  • Signal processing suite: Editing slider values by entering the value with the keyboard is now also possible when playing
  • Other minor fixes
Linux:
  • Other minor fixes
When playing a track from Qobuz or TIDAL, you will see the icon next to the track name:
v3.0.5:
MacOS:
  • “Loading…” does not hide the search results anymore
  • Other minor fixes
Windows:
  • Other minor fixes
v3.0.4:
MacOS:
  • Album details view now loads correctly when no streaming service is connected
v3.0.3:
MacOS:
  • Local library synchronization: WebDAV mounted folders can now read folders and files with accented characters
  • Qobuz: favorites, playlists and purchases updates outside of Audirvāna are now automatically detected when opening a favorites, playlists browse or Qobuz purchases view
  • Other minor fixes
Windows:
  • VST plugins: offline setup popup window does not hide anymore the plugin setup view
  • Transport audio unlock button does not pulse anymore when paused to avoid triggering .NET 10 CPU hogging bug
  • Other minor fixes
Linux:
  • Other minor fixes
v3.0.2:
MacOS:
  • AudioScan now clearly indicates when there when quality is uncertain between lossy compression and lossless
  • Other minor fixes
Windows:
  • Reduce minimum window size to 1024x600 (helpful for integration is some devices)
  • Window can now be dragged when the onboarding is displayed
  • Other minor fixes
Linux:
  • Other minor fixes
v3.0.1:
MacOS:
  • HRA-Streaming: fix browse from Remote App home page
  • Fix playlist manual reordering
  • Fix licence check on legacy macOS versions
  • Other minor fixes
Windows:
  • Other minor fixes
Linux:
  • Other minor fixes
v3.0:
MacOS:
  • NEW Allegro Design: layout & navigation major update
  • NEW Processing Suite: Convolution, CrossFeed and Balance in addition to Equalizer
  • Multichannel: handle custom speakers setup layouts
  • Other minor fixes
Windows:
  • Other minor fixes
Linux:
  • Other minor fixes
