Release note Audirvāna Studio 3.3
Following 2026-06-22T22:00:00Z update of Studio, here is the changelog of the 3.3 version:
MacOS:
  • AudioScan: now displays the track frequency response spectrogram in addition to the global curve (toggle using the switch just above the graph in AudioScan results)
  • Other minor fixes
Windows:
  • Other minor fixes
Linux:
  • SMB share access: use direct access functions instead of mounting the folder with a SUID helper for improved security and better compatibility
  • Other minor fixes
