Hello
I’ve set Audirvana so that I can control the output volume. However when using the remote app and Tidal it seems that the volume of certain individual songs remains the same - ie not correlated to the volume I have just changed on the PC ?
Hello
Yes MQA
Many thanks
Audirvana 3.5.43
SW volume control: ON
Sync list: 2 folders
AUTO: C:\Users\user\Music
AUTO: \TS231\Multimedia
Library database path: C:\Users\user\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2498MB
Local Audio Engine:WASAPI
Speakers (iFi (by AMR) HD USB Audio)
Model UID:Speakers (iFi (by AMR) HD USB Audio)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{f347cbfa-2a4a-4714-9cff-5695842aea89}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Speakers (High Definition Audio Device) Manufacturer:
Model UID:Speakers (High Definition Audio Device) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{f4747817-627f-4c9f-b463-5e9397ebafa9}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
4 available sample rates up to 192000Hz
Simple stereo device: No
Device #0: Speakers (High Definition Audio Device) Manufacturer: Model UID: Speakers (High Definition Audio Device) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f4747817-627f-4c9f-b463-5e9397ebafa9}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Hi Damien
Hope that above is what you were looking for ?
Regards
CB
Yes, can you also give an example of a track you have this behavior?
It seems to be pretty much every MQA Master album but you could try:
Many thanks
Have you tried without Software volume control enabled?
Hello
I had continued issues with MQA. I have now tried Qobuz and this works without issue
Overall I also prefer the sound of Qobuz and it’s cheaper - problem solved!
Best
CB
