I want to use a remote Android app, but it seems that only the same Wi-Fi environment is possible. Since it’s a desktop, I don’t have Wi-Fi. Should I buy a desktop wireless LAN card?
It should work as long as you’re on the same network. It doesn’t matter if it’s WiFi or wired.
